Had a retarded idea, would it work?
Old Nov 7, 2012 | 10:54 AM
SofaKingAzn's Avatar
My lower valence grille is open and I have installed a grille over it. Right now its doing nothing. Only thing its doing is cooling my wiper fluid :P I had a idea to take a hose and lead it from the lower valence and attach it to the intakes (The two small openings leading to the air box). Not looking for performance gains just want my lower valence grille to do something, Is it a retarded idea as in it'll suck in water or something? Thanks
Old Nov 7, 2012 | 11:17 AM
Austin713's Avatar
yes. the lower the intake the better chance it has to intake water during a flood. why did you remove the lower valence? im assuming you have the Journey, so thats a pretty big gaping hole to fill.
Old Nov 7, 2012 | 12:03 PM
willdogs's Avatar
Our intakes already get direct air from the outside thru the grille. Ram Air effect
Old Nov 7, 2012 | 12:32 PM
dukehotty's Avatar
I like the way you think. Check out these pics!
https://g35driver.com/forums/engine-...-new-post.html
https://g35driver.com/forums/engine-...-anti-56k.html
Old Nov 7, 2012 | 12:58 PM
Adro's Avatar
Not trying to shoot these Ideas down.....but I highly doubt the gains are worth the effort to do this mod. However, I'd love for someone to show some dyno'd proof of the gains and prove me wrong!
Old Nov 7, 2012 | 01:16 PM
willdogs's Avatar
Originally Posted by dukehotty
V36 2007+ Sedans already have this Stock from Factory
Old Nov 7, 2012 | 05:03 PM
ughhh not sure. mine's a x so its the real ugly one with 2 huge plastic valence. Its not fully cut open. Right now its partially open and there is a after market grille over it.
Old Nov 7, 2012 | 05:53 PM
dukehotty's Avatar
Perhaps you can post a picture of this aftermarket grille?
Old Nov 7, 2012 | 08:05 PM
its nothing special. Look in my garage. I bought it just to cover the opening up a bit. But still plenty of air flow that's why I was thinking of utilizing it.
Old Nov 9, 2012 | 11:28 AM
soundmike's Avatar
As most mentioned, the G already has a ram air set-up for the OEM intake (IIRC, up to 6hp at speed per their old marketing material.)
How about brake cooling ducts?
JMSABO
Aug 4, 2015 11:58 AM
bjo16
Aug 4, 2015 09:52 AM
Rehman2009
Jul 27, 2015 03:23 AM
myaso
Lighting
Jul 22, 2015 10:34 PM
