Car wont start
Dec 13, 2012 | 11:00 AM
recently my key battery had gon out and me being the genius that I am started leaving my key fob inside the car while i was at work and now my car won't start without a jump. Any ideas on what the problem is?
Reply 0
Dec 13, 2012 | 12:03 PM
Quote: recently my key battery had gon out and me being the genius that I am started leaving my key fob inside the car while i was at work and now my car won't start without a jump. Any ideas on what the problem is?
Most obvious answer if your car needs a jump...your car battery died.
If you left your key fob in the hole too long your car battery will start draining to connect with that key fob.
Reply 0
Dec 13, 2012 | 12:36 PM
Quote:
... I am started leaving my key fob inside the car
... now my car won't start without a jump.
IDK, but I'm guessing you either need to look in the mirror or stop trolling.
Reply 0
Dec 13, 2012 | 01:38 PM
Well the only reason I ruled out the battery because when I called AAA battery service the guy said it was my alternator...but im guessing he just didn't wanna do the work n put the battery in
Reply 0
Dec 13, 2012 | 02:26 PM
Quote: Well the only reason I ruled out the battery because when I called AAA battery service the guy said it was my alternator...but im guessing he just didn't wanna do the work n put the battery in
If your alternator is dead, you can do a simple test. While your car is on, turn on the headlights. While the car is in park, and you press the accelerator button and the headlights change intensity then your alternator is dead.
You can also remove the negative terminal while the car is running. If the car dies, then your alternator is bad.
If you need to jumpstart your car that means your battery is bad. Based on your story, it definitely sounds like a battery.
Reply 0
Dec 13, 2012 | 05:56 PM
Quote:
...You can also remove the negative terminal while the car is running. If the car dies, then your alternator is bad.
NO, NO, NO . . . DO NOT DO THIS !!!
You can damage your car's electrical system by doing that. It was a valid practice in much older cars, but pretty much any newer car will loose proper voltage regulation and potentailly fry something expensive, like the ECU.
Reply 0
Dec 13, 2012 | 06:19 PM
we have an accelerator button?
Reply 0
Dec 13, 2012 | 07:37 PM
Quote: we have an accelerator button?
Haha, sorry for my typo. Don't follow my advice. I don't want your car to have a damaged ECU with a neg. terminal gone.
Reply 0
Dec 13, 2012 | 09:12 PM
Sadly, considering it's a DBW setup, it's actually not terribly far from the truth.
Reply 0
