Did my DYI brake bleed with ATE blue over the weekend
Old Mar 18, 2013 | 01:44 PM
stockae92's Avatar
Did my DYI brake bleed with ATE blue using the power bleeder.
This is a great thread and helped me out a lot: https://g35driver.com/forums/v36-diy...r-bleeder.html
Each bleed valve has a rubber boot on it, and I took them before I took that photo.
For G35S stock sports brakes, the size of the bleed valve in the front needs a 9mm wrench and the rear needs a 8mm one.
I had a stucked rear wheel that won't come off even after I remove all the lug nuts. I was told to losen the lug nuts a little and drive it for a few feet back and forth. I did that twice and I got the wheel "unstucked".
The blue brake fluid made it easy to spot when the old fluids is out when you see the fresh blue color coming out of the bleed valves.
You should also have plenty of shop towel and water handy, especially if this is your first time doing it. trust me on this one.
After the brake bleed, the brake pedal feels a little firmer and the brakes still work. I guess that's a good thing. haha. This is a pretty straight forward DYI with all the right tools, and this gets you to know your car a little better.
Old Mar 21, 2013 | 07:34 PM
Triton3.5's Avatar
nice,, thats what i used last year to do this,,, Ate, blue
jcardodeucedos
Aug 27, 2015 06:28 PM
sinasajadi
Aug 26, 2015 04:12 AM
mdzukunft
Drivetrain
Aug 25, 2015 10:28 AM
linedr89
Aug 17, 2015 05:11 PM
mushu
Jul 15, 2015 03:55 PM
