Cause for the dreaded P0011/P0021 codes that everyone is curious about
Rating: Thread Rating: 4 votes, 4.00 average.
  #361
Old 10-09-2016, 09:07 PM
vqsmile's Avatar
Originally Posted by Sam G35S
This is one of my biggest worries about my 2007 G35S Sedan I just got 2 months ago,what's the mileage of this issue that occurs?And when it happens can you still drive the car(make a home safe without damaging anything) or you just stuck whenever happens?And also can this said plate gasket can be replace just by removing front cover and not remove the timing chains and tensioners?
ALL your answers are contained within this thread if you read through it thoroughly, but briefly:
1) there is no particular mileage that this occurs.
2) yes, you can probably still drive it, although you'd want to minimize it to be sure.
3) yes to removing just the front cover, but no, probably still need to remove timing chain.
  #362
Old 10-09-2016, 09:08 PM
willdogs's Avatar
Originally Posted by vqsmile
Since I'll never own another BMW, I decide to pick up a little rental car from down under:
They are 20% off right now, so I couldn't pass it up.
Oh Man Amazing!!! Any Pics? Congrats! super jealous
  #363
Old 10-09-2016, 09:11 PM
vqsmile's Avatar
Bought and paid for, but it's still sitting at the dealership (long story). Here's the only pic so far:
  #364
Old 10-09-2016, 09:30 PM
willdogs's Avatar
Awesome the same color I would have went with. Congrats again
vqsmile (10-09-2016)
  #365
Old 10-10-2016, 10:42 AM
blnewt's Avatar
Congrats Cliff, nice upgrade for sure! Just need some rear Brembos to finish it off
http://www.ssforums.com/forum/wheels...s-finally.html
vqsmile (10-10-2016)
  #366
Old 10-10-2016, 10:52 AM
blnewt's Avatar
VQsmile singled out a few posts w/ important info in that thread, check post #70 & 90, and then this post that contains an Adobe link that details all the work involved in "just" removing the front cover to R&R those gaskets, even that job will be a total PITA
https://g35driver.com/forums/g35-sed...ml#post6947172
Sam G35S (12-04-2016)
  #367
Old 10-10-2016, 11:16 AM
vqsmile's Avatar
^^ That was the 2014. The 2016's come with them on all corners:
Other 2016 Chevrolet SS chassis features include:
•Standard Brembo brakes with four-piston calipers and ventilated, 14-inch(355mm) front rotors and 14.2-inch (360 mm) rear rotors
not my pic:
  #368
Old 10-10-2016, 11:27 AM
blnewt's Avatar
Nice! Well learn something new every day I guess I only see older SSs rolling around here
Scratch that off your shopping list!
  #369
Old 11-25-2016, 01:39 AM
rr1982's Avatar
I have a problem with my 2010 Infiniti G37 xs Sedan Uprev tuned. I'm getting a p0021 code and the engine cuts out at about 3500 rpm, no low oil pressure light or code.Do these engines have the bad timing cover gasket problem? Hopefully not. Is the issue most likely an INTAKE VALVE TIMING CONTROL SOLENOID VALVE, forgive the caps, or a bad cam position sensor? Also what ever happened to Infiniti dude who started this thread?
  #370
Old 12-03-2016, 11:24 PM
rr1982's Avatar
Had the P0021, pulled the left cam gear cover,the cam solenoid was bad,replaced it and the cam position sensor, started it up with oil pressure tester on,37 degrees f out let her warm for about a half hour or more, settled at no lower that 20 psi @idle and 50 psi @ 2000 will within spec no cels.I will remove pressure gauge tomorrow and test drive it will be hammered on!So far it's not a bad timing cover gasket.
  #371
Old 12-04-2016, 12:14 AM
Sam G35S's Avatar
So all you did was remove the small access plate/cover and how did you discover the bad solenoid and was the replacing the solenoid replacement easy? Thanks
  #372
Old 12-04-2016, 12:19 AM
Sam G35S's Avatar
Thank you blnewt
  #373
Old 12-04-2016, 12:27 AM
rr1982's Avatar
The P0021 without any oil pressure code made me decide to test the solenoid.When I disconnected the connector I tapped on it lightly to loosen the seal and the **** cracked. So I had to pull the cover to get the broken solenoid insert out.when I looked in the solenoid housing area there was a small piece of it deep in the recess. So I ordered a new solenoid, replaced it and the 3 cam seals around the shaft inside the housing.She started right up smoothly,The oil pressure was steady and strong no codes. I'm praying the code doesn't come up again. I'm switching to the Nissan ester,fuçk it! The Parts guy at Infiniti said hes not aware of any timing cover gasket issues with the 2010.Be careful removing the cover.Theres 8 -10 mm head bolts to remove,theyre all easy.Unbolt the coolant reservoir first. I used a straight screw driver and a small rubber hammer to wedge it off in the gap side to side, you can't pull it with fingers. As always, I will report back.
  #374
Old 12-04-2016, 09:23 AM
Sam G35S's Avatar
That's awesome if that fix the issue,how much was the part and did you get it from the dealer? Thanks
  #375
Old 12-04-2016, 11:58 AM
rr1982's Avatar
Rock auto $122 + 10 shipping Hitachi oem
You have already rated this thread Rating: Thread Rating: 4 votes, 4.00 average.
Quick Reply: Cause for the dreaded P0011/P0021 codes that everyone is curious about
