Tinted tail options?
Old Jan 13, 2014 | 03:55 PM
Rinaldi's Avatar
What options are there to tint the tail lights on the sedan?
Old Jan 13, 2014 | 04:21 PM
Urbanengineer's Avatar
You can paint em, use a tint tape, or buy bluebatmobile overlays. The overlays are so nice for the V36.
Good luck!
Old Jan 13, 2014 | 05:02 PM
blnewt's Avatar
Painting looks best if done properly, here's my DIY for a GTR style painted taillight, and I can send stick-on templates if you're interested
http://www.myg37.com/forums/d-i-y-in...ils-sedan.html
Old Jan 13, 2014 | 05:55 PM
Lartytiejdke3's Avatar
Old Jan 13, 2014 | 07:34 PM
mishmosh's Avatar
Remove the tails and then get a spray can of Nite Shades and Clear coat. It'll turn out really good. Some good videos on Youtube if you search.
Vinyl overlays are not easy to install at all. I have applied tint to windows before but applying overlays must involve a whole different skill set because I botched my attempt--big waste of time and money. Couple coats of Nite Shade and clear coat is much easier IMHO.
Old Jan 13, 2014 | 08:16 PM
blnewt's Avatar
Agree, my DIY that I posted above uses the Niteshades/clearcoat method but also has the barely tinted LED rings and side markers for the GTR look and shouldn't attract attention from the law compared to entire tail tint, also looks factory IMO.
I installed headlight & taillight overlays successfully but it's not an easy DIY, especailly if you've never worked w/ vinyl prior.
Old Jan 13, 2014 | 08:25 PM
gary c's Avatar
Painted tails (body color) look the best, do a Search there are several DIY threads showing you what they look like and how it's done...Gary
Old Jan 14, 2014 | 11:34 AM
SofaKingAzn's Avatar
Did mine with niteshade and got a local body shop to do a couple of clear coats on it. I feel like clear coats brought from store is not thick and shiny enough. I wanted the thick enamel look.
Old Jan 14, 2014 | 12:30 PM
thegreatkwijibo's Avatar
your best option is to not tint them.
Old Jan 14, 2014 | 01:51 PM
Rinaldi's Avatar
I have a white G with black wheels and the tails to me just seem to stick out.
Old Jan 14, 2014 | 03:18 PM
blnewt's Avatar
Agree, the cans you buy from auto paint supply places for cut-in of door panels are a good clear coat for the tails, goes on thick and buffs to a factory shine, I used Dupont Acrylic Clear A-7480s, also good options are Evercoat Cut-in-Clear, Spraymax 2k cut-in-clear.
The Krylons, Rustoleums, etc aren't a good option for a pro quality job.
Old Jan 14, 2014 | 06:38 PM
Yepp Avoid Krylons clear coat at all cost, I mean at all cost. I first did mine with the Krylon and the clear coat never seems to dry, after 2 weeks it was still slightly sticky and when it's hot out it's incredibly sticky. Then after I went with a duplicolor clear coat, it was a lot better. But at the end just gave up and Sanded most of the clear coat off for a body shop to do :P
Old Jan 14, 2014 | 07:16 PM
saywat?'s Avatar
pls do not color match ur lights. it will look horrible
Old Jan 23, 2014 | 11:44 PM
G35DriverNC's Avatar
I don't have any experience with painting them but want mine easily reversible in the future if needed, or if I didn't like it. I got all my Vinyl from Don Nguyen (on lots of forums and here) since I knew the product would be good.
I did it myself and turned out real nice. Smooth and shiny. A little wavy texture on the surface up close but not noticeable to anyone really. Definitely cuts out some of the sharp red that was distracting to me. I used the lightest tint shade.
You definitely need a heat gun to get it to form around the sedans curves properly.
You can see the difference on the two sides below, then again on the right tail with the truck piece not tinted.
Old Jan 24, 2014 | 09:43 AM
See, that looks good^
Its not ricey and with the black roof(props) it flows great.
Only thing I don't get is , how is the red distracting to you?!!?!!!! Lol
