How much drop before I need camber kit?
Old Apr 11, 2014 | 07:54 PM
  #31
PLENUMCOUPE's Avatar
^id like to see the specs with the drop b4 the arms and then with the arms pls
Old Apr 11, 2014 | 09:36 PM
  #32
ScraggleRock's Avatar
After eibach pro kit, before any camber kit:
after rear spc kit and eccentric toe bolts:
After kinetix arms and Energy compression rods (poly bushings currecting caster):
Old Apr 11, 2014 | 11:10 PM
  #33
saywat?'s Avatar
Originally Posted by Gdirtyfive55
In my head? I don't think so, my friend. Riding on 2 inches of the inside of my tire vs 10 inches of tire makes quite a noticeable difference. It's called contact patch and its real.
You're talking about the V1 kinetix with the exposed balljoint. Total pos, but also totally different animal. They fixed the problems and covered the joint. Kinetix has the most adjustability for camber of any arm, its a set it and forget it camber setting and the ball joint is a seperate piece so when it needs replacing you can buy just the joint rather than whole new arms. I'll post my before and after alignment specs if you'd like.
Lol well at 2 inch of contact if that's the case like u say then for sure ill feel a difference
Old Apr 11, 2014 | 11:18 PM
  #34
Shawno72's Avatar
After swift springs and spc rear camber arms and for bolts. Stock front upper a arms.
Old Apr 11, 2014 | 11:34 PM
  #35
Yeah, man, my tires would look brand new except for the inside 2 inches. I was basically riding on pizza cutters.
Old Apr 11, 2014 | 11:37 PM
  #36
Shawn, my friend your caster is telling me that you need some comp rod bushings.
Old Apr 12, 2014 | 09:23 AM
  #37
Urbanengineer's Avatar
And he happens to sell them... Huh.
Old Apr 12, 2014 | 09:38 AM
  #38
Shawno72's Avatar
Out here in Cali the roads have a lot of crown so a little caster on the right helps it to go straight down the road. Besides caster doesn't affect tire wear
Old Apr 12, 2014 | 11:11 AM
  #39
thats interesting that u say that bc they gave me a little more camber for that exact same reason-
Attached Thumbnails How much drop before I need camber kit?-image-2208777064.jpg
Old Apr 12, 2014 | 12:53 PM
  #40
Ha! Whatever, dude, he can buy them from whomever he wants (or not at all), I just like things to work properly.
NohoG35revup
Aug 22, 2015 12:13 PM
Dundermuffin666
Aug 14, 2015 04:01 PM
socalg35x
Aug 7, 2015 09:36 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
nascarbuff17
Jul 16, 2015 10:23 AM
