60K Service
Old Jul 9, 2014 | 02:25 PM
Eclipse2G35's Avatar
60K Service
Hi guys,
My 60K service is overdue. I plan to buy all the fluids and get a local shop to do the service. Am confused on what fluids to change and which brand fluid to get. What else is recommended for 60K service? Thanks for your time.
Old Jul 9, 2014 | 03:23 PM
Shanes_G's Avatar
Just google 60k service g35
Old Jul 9, 2014 | 03:43 PM
ScraggleRock's Avatar
Originally Posted by Eclipse2G35
Hi guys,
Just change coolant, oil, diff fluid, tranny fluid and check all belts and hoses. Its a little early for the tranny, but better to be early than late. Might as well get it over. Especially if you're an auto.
Also, have them check all your bushings.
Old Jul 9, 2014 | 03:47 PM
Urbanengineer's Avatar
Definitely do the transmission fluid.
Old Jul 9, 2014 | 03:53 PM
And the tranny and diff fluid it is highly recommended to use stock Nissan fluid. You can go redline or royal purple or something if you want, but my buddy is having grinding issues after using royal purple. Its Not a G35, and its hard to pin on the fluid specifically, but he changed it plenty early so I dunno..
Old Jul 9, 2014 | 03:56 PM
Shanes_G's Avatar
Plugs
Old Jul 9, 2014 | 03:59 PM
Originally Posted by Shane-O-Mac
Plugs
I would personally do plugs, cuz I like that **** being brand new, but he has iridium plugs, so he could go to 90k on them.
Old Jul 9, 2014 | 04:54 PM
so which ATF and differential fluid do I get? is it this: http://www.thenismoshop.com/NISSAN-M...00P_p_311.html
How much of each do I need?
Old Jul 9, 2014 | 04:57 PM
No, that one says not for RWD .
Should be matic-s
http://www.thenismoshop.com/NISSAN-M...00P_p_304.html
Old Jul 9, 2014 | 05:17 PM
Should be matic-s
Just looked in the manual and it says Genuine NISSAN Matic J ATF*3. You are right. The name must have been changed from S to J. Can anyone shed on the quantity i need fot the ATF and gear oil, couldn't find info in the manual. Thanks
Old Jul 10, 2014 | 08:27 AM
galperj's Avatar
Too early for plugs
Guys, if you ever read the manual, it recommends changing the spark plugs at 105000 miles.
For Iridium plugs we have there's no need to change them earlier. It's just waste of time and money (unlike older cars it's rather time consuming, 2+ hours labor + parts = around $350)
Old Jul 10, 2014 | 09:39 AM
This is true, but mine were in horrible condition at 105K and should have probably been replaced around 80-90k. OP. Find a good deal on them then consider it!
Old Jul 11, 2014 | 08:27 AM
equifire's Avatar
There's a DIY for fluid change that tells you everything you'd need to know. If you have access to the basic tools it's pretty straight forward to do yourself.
https://g35driver.com/forums/v36-diy-378/
Old Jul 13, 2014 | 04:30 PM
vqsmile's Avatar
No, Matic-J is no longer available. It has long since been superseded by Matic-S as the current spec for V36 generation automatic transmissions.
Also, a friendly tip when seeking specific advice for your car: you should always include the year/make/model specs for your car, regardless of which forum section you posted in. Some people put it in their sig or at least in their profile or garage info. In your case, that info is no where to be found, so it leaves you vulnerable to potential misinformation.
.02
Old Jul 13, 2014 | 04:44 PM
$350? Try $50. Do it yourself.
Diode Dynamics
Accessories-Vendor
39
Nov 30, 2021 02:28 PM
infinitiway
Aug 8, 2017 12:38 PM
f22raptor
Mar 18, 2016 08:50 AM
heynow
2nd Gen (V36) Sedan
Oct 28, 2015 05:09 PM
