Please help: Dash lights starting to go out
Old Jun 27, 2015 | 06:02 PM
ce3po's Avatar
I have an 08 with 133K miles. About a month ago the back light on the clock at night started to flicker. About 1/4th of the clock from 9 to 12 is now completely dim at night. How do I fix this? Also the temp gauge backlight on the left side of the dash is starting to flicker too. I suspect that will go out soon. Any input on how to fix this too would be appreciated? Thanks.
Old Aug 4, 2015 | 08:51 AM
Roddy914's Avatar
I'm having this same problem did you find any help for it?
Old Aug 4, 2015 | 11:54 AM
ce3po's Avatar
No response
I haven't heard from anyone else on this forum. Did some research and it sounds like alot of work pulling the steering wheel off and instrumental off to fix loose connection or faulty LEDs. Saw an outfit on ebay that will fix all leds on instrumental panel if you send it to them. I believe it was like $300. I am just going to live with it unless it affects other instruments besides temp guage.
Old Aug 4, 2015 | 02:19 PM
LCC0256's Avatar
Journey Sport Package Nav
My tach lights are intermittently going on and off between 5 and 8. Haven't had issues with other gauges. Read up on this also realizing it's a PITA to fix. Just gonna live with it. 08 Journey 194k
Old Aug 9, 2015 | 10:58 AM
LCC0256's Avatar
The lights on my tach are back to 100% fully functioning...i started wearing the tin foil inside my cap again...im sure that had something to do with it...
Old Sep 22, 2015 | 08:19 AM
KC23's Avatar
Same here on this problem
Lights slowly going out on the dash mostly from left to right. Dealer wants like $800 to fix it.
wonderizm
Sep 24, 2015 03:09 AM
Wayne9011
Aug 17, 2015 01:24 AM
Wayne9011
Jul 27, 2015 11:25 AM
