Did my first oil change today and noticed an obvious problem!
Old Oct 31, 2015 | 04:03 AM
gcvt's Avatar
WTH? What is it, 634 bolts holding the belly pan on?! Anyone ever modify their belly pan to make oil changes easier?
The drain bolt and filter are so close together, it seems like you could just cut out a small (maybe 8"x12") access door, rivet a section of piano hinge on the driver's side, and put a Dzus fastener, or some other type of quick release fastener, on the passenger side and save yourself a lot of time. Release fastener, flap folds down, drain oil, replace filter, re-do fastener...done.
Any reason not to do this??
Old Oct 31, 2015 | 04:48 AM
Tyke420's Avatar
They have aftermarket undertrays you can buy... If you wanna cut out a bigger access spot then by all means do it... Not too much too think about here...
Old Nov 1, 2015 | 12:59 AM
tbear35's Avatar
Yeah, just changed my oil a couple of hours ago. Took way longer to remove the tray than actually drain oil and change filter. Can't imagine that a quick lube place would ever do it correctly.
Old Nov 1, 2015 | 01:11 AM
gcvt's Avatar
I plan on keeping this car for a while. I'll post a DIY when I do this
Old Nov 1, 2015 | 01:39 AM
ScraggleRock's Avatar
Take off undertray; don't put back on; change oil in 10 mins.
Goddamn, I'm a genius.
Old Nov 5, 2015 | 08:59 PM
JOKER's Avatar
CLUB MODERATOR
yall know that stock belly pan only required to be taken off in the front and then it bends down to give access to the drain plug and filter, or in the back and then it flips forward. Cant remember exactly it was a long time since I had a stock belly pen on. You don't have to take off entire thing off the car. Might as well change the oil from the sun roof in that case.
Or get aluminum aftermarket under tray with built in door that's held by two little bolts.
Old Nov 5, 2015 | 11:49 PM
blnewt's Avatar
Our previous 07 Sedan and our Current 09 Sedan has a crease in the back of the splash pan so you can easily pull it forward to access the oil filter and drain plug. Only 4 bolts to remove.
Old Nov 6, 2015 | 01:43 AM
gcvt's Avatar
Originally Posted by treacherous
It doesn't help here but the X has a trapdoor for the filter and opening for the pan plug. Just two 10mm bolts.
My BMW had that. Miss that.
Old Nov 6, 2015 | 11:48 AM
Texasscout's Avatar
Milwaukee 2457-21 3/8-in Cordless M12 Lithium-Ion Ratchet Kit - Power Drill Accessories - Amazon.com Milwaukee 2457-21 3/8-in Cordless M12 Lithium-Ion Ratchet Kit - Power Drill Accessories - Amazon.com
linedr89
Accessories
Feb 24, 2016 01:00 AM
linedr89
Engine - Intake/Fuel
Oct 27, 2015 09:11 PM
cxlo8331
Accessories
Oct 13, 2015 01:37 PM
brane123
Intake & Exhaust
Oct 12, 2015 11:25 PM
Robert Young
Oct 7, 2015 07:38 PM
