Driver's door exterior unlock button not working
Old Dec 8, 2015 | 10:07 PM
silverG2007's Avatar
The button you push on the outside door handle on my driver's door stopped working.
For about a week, it only worked if I pushed it really hard, then stopped working altogether.
Anyone know where to buy a replacement part, what the part is called, and the process to replace?
I'm hoping it's just a matter of switching out either the button or handle. After 9 years in this car, using the key fob to unlock just seems like too much work. :P
Old Dec 8, 2015 | 10:32 PM
BradMD_96's Avatar
By 'button you push on the outside door handle' do you mean the part that swivels which is around the interior door handle? If so, that is connected to a small rod on the inside of the door panel. When I bought my G, both were disconnected so the car had to be electronically locked/unlocked to get out. Looking at the small rod which hooks on that part, it's no surprise they fall out and disable the lock.
Old Dec 8, 2015 | 11:02 PM
I mean the little black button on the door handle on EXTERIOR of the car.
The thing you push that unlocks the door (and beeps when you do).
I found the name for it, "door handle request switch."
FWIW, it works perfectly fine on the trunk and the passenger door, and has worked for 9 years up until about a month ago. I've also double checked the settings in the menu and the intelligent key door unlock is enabled.
Old Dec 9, 2015 | 07:05 PM
MaxumG35's Avatar
Mine has started recently not working on the first push anymore. Now, I have to press it like 4-5 times for it to unlock in the morning and same with the key fob. But after the first unlock, it works on the first push for the rest of the day.
Old Feb 14, 2016 | 10:35 PM
Still can't find a part or part number.
Anyone know where to start?
Or is there a fix by opening up the guts of the door?
Old Feb 14, 2016 | 11:44 PM
vqsmile's Avatar
Is it not part of the outer door handle? You have to pick the your color to get the correct part number.
http://www.trademotion.com/parts/200...e%2C%20outside
You might look on e bay:
http://www.ebay.com/sch/Exterior-Doo...=179851&_ssc=1
Old Feb 26, 2016 | 07:58 PM
Thanks! I'm thinking that would probably do it since it's the whole part.
Now anyone have any clue how to install or uninstall it? If I can access it, maybe it's as simple as a loose wire connection!
Old Feb 26, 2016 | 09:05 PM
vqsmile's Avatar
http://www.nicoclub.com/FSM/G35/Seda..._Sedan/dlk.pdf (see page DLK-207)
Old Apr 16, 2016 | 03:21 PM
Ended up getting the handle on Ebay, but didn't have a chance to install it. Gave it to the guy who bought the car off me yesterday.
Upgraded to a 2015 Chevy SS. So far I'm loving the magnetic ride suspension and 415hp!
Old Mar 15, 2021 | 08:51 AM
Mry's Avatar
Mry
Tech package
Sorry this so late but.....
If the key Fob is in the same hand when you push the entry button it will NOT work.. Put the Fob in your pocket never in your hands ..🙋
mathnerd88
Mar 9, 2019 02:14 PM
WxAxGxS
Jun 16, 2017 03:10 PM
infuniti
Interior
Oct 20, 2015 12:35 AM
VCG35
Apr 19, 2010 08:56 AM
kring
Feb 21, 2007 08:00 AM
