O2 sensor wiring help
Old Oct 5, 2016 | 12:20 AM
whitev36's Avatar
Hello , got a problem with the G...
The other day the sel light came on so checked it out and it is an O2 sensor code. Got under the car to check it out and found the plug from the factory harness attaching to the downstream O2 sensor was ripped off. The car is lowered so it does scrape once in a while. I bought a new bosch sensor but not sure how to plug it in so now I have a couple questions:
1) does anyone have a plug/harness they can sell? I know the sensors interchange with other cars so as long as it plugs in we are god to go.
2) can someone help me find out what wire color are the 2 grounds the signal and the heater? mines are white, black, pink and green.
Thanks in advance
Last edited by whitev36; Oct 5, 2016 at 12:24 AM. Reason: messed up on some spelling and added a couple words
Old Oct 14, 2016 | 04:40 PM
infinitidude's Avatar
Old Oct 14, 2016 | 04:42 PM
This is on the harness side looking at the back of the broken connector and this is how the wires will need to be arranged. Once you get it all hooked back up make sure all of your fuses are good. Sorry for the delayed response brother.
Old Oct 14, 2016 | 05:25 PM
whitev36's Avatar
Thanks bro this really helps alot..... now to fix it and off to the smog shop.
Old Mar 1, 2021 | 08:07 PM
DanielG2506's Avatar
G35 coupe
I have the same issue right now, did you manage to fix it?
Old Dec 7, 2024 | 03:29 PM
Alan.vqhr's Avatar
Infiniti G35 Sedan Journey Trim, VQ35HR
Did you ever figure out where to get a new sensor or how to make it connect? I have the same problem I just need it to work for emissions,
Old Dec 7, 2024 | 03:36 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
You can cut the harness off of a donor vehicle at a salvage/wrecking yard and solder splice it onto your vehicle. Then it's just an easy color-for-color splice.
Alternately they do make replacement aftermarket harnesses.
elrooko
Intake & Exhaust
Sep 5, 2022 08:24 PM
Worin
Dec 1, 2019 09:03 PM
crystal80
Aug 7, 2019 03:41 PM
KevinE
Intake & Exhaust
Apr 19, 2011 05:52 PM
