Program new key?
Old 08-04-2017, 09:04 PM
Jetranger's Avatar
Program new key?
I just purchased a 2008 G35s......Black on Black, put my first hundred miles on it. NICE! Looking for some help, I only got one remote key with the car (4 button), I would like to get another key. I see tons of them on the internet, but it would have to be programmed.
Can anyone comment on the cost to have it programmed? And, I do not have the tag or card that I understand has the code for the car......can it still be done?
Thanks,
Jet
Old 08-05-2017, 11:32 AM
cleric670's Avatar
BANNED!!!
Received 2,469 Likes on 2,161 Posts
Coupe 6MT Premium RAS
There's two different systems and I'm not sure which you have, first is the standard RFID key + fob, the other is the Nissan "intelligent key". If you have a push-to-start button on the dash you have the intelligent key system and the whole process will need to be programmed by the dealership.
If you have to insert a key into the ignition to start then you have so.e options, adding a physical KEY will require the RFID to be programmed on the key for it to work, adding just a fob however is easy, the programming can be googled and just requires you to actuate the door lock, ignition, fob in a specific sequence to program it to the vehicle.
Old 08-05-2017, 12:39 PM
Jetranger's Avatar
Thanks for the help.......I have the push button start, so the "intelligent key"
Old 08-05-2017, 03:09 PM
Mr.GEE's Avatar
You may want to try a locksmith in your area, I had my key fob program at a locksmith's shop for less than half of the dealer's $120 charge(price from 6 years ago) and they even cut the pull out key.
Old 08-05-2017, 04:17 PM
Jetranger's Avatar
Locksmith is a great idea ! Thanks... Does anyone know if the key fobs like mine I see on ebay for for $20.00 will work ok?
Old 10-08-2019, 04:21 AM
Mauricewhite's Avatar
na
Moderator EDIT: More locksmith botting, holy hell...
Old 10-08-2019, 07:34 AM
scumbagsleeper's Avatar
1990 Mustang GT - 351W Lightning bored/stroked 383CI TFS heads 78mm Turbonetics huricane
In case anyone is looking for a DIY duplicator and fob for intelligent FOB / pushbutton start cars:
https://www.dormanproducts.com/p-832...origin=keyword
They are about $90 at rockauto.com. That's what I'm getting for both of our 08' G35x's
https://www.rockauto.com/en/parts/do...y+remote,10433
Old 10-08-2019, 08:54 AM
Hoagy's Avatar
AWD Sedan
I just checked with the dealership about getting a spare made, $190 for the RFID "intelligent" fob, $15 for the key that goes into the fob, and $120 for programming the key to my car. Even the guy at the parts counter told me to look elsewhere for key blank and fob, I've seen them as low as $50 on Ebay.
Old 01-26-2020, 03:32 AM
TaylorWase's Avatar
na
Moderator EDIT: Sweet baby Jesus another locksmith bot.
Old 01-26-2020, 02:22 PM
You can buy a used one or aftermarket FOB on ebay and have the dealership program for $120. I have my local locksmith cut the blank keys for $6 each. Just a tip, make sure if buying a aftermarket FOB that they have good feedback and they are the correct type because Infiniti will charge you $120 even if they can't program the new unit.
Old 05-12-2020, 11:07 AM
EliOwen's Avatar
na
Moderator EDIT: What in the **** is with all these locksmith bots!?!?
Old 05-20-2020, 06:14 AM
909's Avatar
909
909 is offline
Your mom's boyfriend
Look on craigslist or similar
In my city the going rate for re-program is $30 if you provide the blank
Old 05-25-2020, 09:11 AM
AntonyGuill's Avatar
bmw
Moderator EDIT : GoDDaMiT aNoTHeR LoCKSMiTH BoT!!!!
Old 11-25-2020, 12:13 PM
Chris Sabin's Avatar
na
locksmith
Moderator Cleric670 edit: Locksmith spam bot.
Old 11-26-2020, 09:48 AM
DrewMcintyre's Avatar
na
Pretty funny they picked two names of professional wrestlers.
Quick Reply: Program new key?
