Front engine noise whine
Old Jan 27, 2018 | 07:45 PM
Jhansenscu's Avatar
Anyone know what is causing this noise at low speed acceleration? 2007 G35 sedan with 157K. Not sure if it’s just normal older car engine noise.
Thanks
Old Jan 28, 2018 | 12:36 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Sounds like power steering whine, have you added any power steering stopleak fluid? The system can be a pain to flush and my go-to method for years has been to buy two quarts of the recommended fluid and a sacrificial turkey baster. Use the baster to drain the fluid reservoir, and refill, go for a drive, come back, rinse/repeat over the course of several days until you have fluid exchanged 2 quarts.
If it's the stock power steering fluid then chances are there are other worn components in the system and it's "just normal older car engine noise" as you said.
Also possible it's belt whine from extremely old accessory drive belts.
Old Jan 28, 2018 | 06:09 PM
Urbanengineer's Avatar
Sounds like a power steering needing a flush!
Old Jan 28, 2018 | 06:55 PM
Triton3.5's Avatar
all what they said ^^ and or the pump is going out....
Old Jan 28, 2018 | 06:58 PM
Jhansenscu's Avatar
Thanks guys! I’ll try the power steering troubleshooting first!
denav35cpe
Mar 15, 2012 10:01 PM
clokwork
Drivetrain
Oct 6, 2008 09:09 PM
CoolCatGee
19
May 31, 2005 02:55 PM
ARTofAWD
Mar 5, 2005 07:23 PM
mvorion
Mar 22, 2004 07:31 PM
