Crashed my G35, need advice on what to do with it
Old Mar 2, 2018 | 02:09 PM
ssuperchieff's Avatar
Unhappy Crashed my G35, need advice on what to do with it
I damaged my G35. Slid on ice and hit the front and rear quarter panels on the passenger side. Apart from body damage, headlight housing and wiper fluid reservoir is cracked, and the trailing arm in the rear is bent causing misalignment. A body shop quoted me at $10,000 for the repair and said it would take 8 weeks to fix. They said it's a 'difficult car to fix'. I'm thinking about selling it as-is since the engine and transmission are still perfect, as well as the interior. I want to know what you guys think I should do with it.
Old Mar 2, 2018 | 03:18 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Get a second quote, call all the new car dealerships in town and ask who THEY recommend for body work and compile a list, that will tell you who does the best work in town usually.
There's no such thing as a "hard to fix" car, sounds like they're blowing smoke up your ***. Body work is body work is body work.
Old Mar 2, 2018 | 03:19 PM
cleric670's Avatar
BANNED!!!
Also, what does your insurance say?
Old Mar 2, 2018 | 03:21 PM
cswlightning's Avatar
pictures needed but sounds like a partout
Old Mar 2, 2018 | 03:34 PM
Definitely not a part-out. I should note that I was an idiot and removed the trailing arm myself and I couldn't get it back on. Looking underneath though that did seem like the only chassis component that failed. Everything else matches up with the other side. I'll post pictures in a reply.
Old Mar 2, 2018 | 03:39 PM
Some pictures. Note the rear wheel looks that bad because of two reasons: I was an idiot and I removed the bent trailing arm and couldn't get it back on, and my driveway is sloped which is why the wheel is resting in that position. When I was underneath I matched the chassis components on both sides and everything matched up fine, only the trailing arm was bent. Doors, hood, and trunk still open.
Old Mar 2, 2018 | 05:38 PM
cleric670's Avatar
BANNED!!!
You can eBay that arm if you can't find one locally for cheap. Very inexpensive part.
Old Mar 7, 2018 | 06:28 AM
Blue Dream's Avatar
I drove ttrank's car solo
Your car is most likely going to be totaled by the insurance company. Casual visual inspections are limited at best, this type of collision usually causes a ton of damage the untrained eye will not spot. Get a second inspection from a reputable source and check with insurance on where they will go from there.
Old Mar 7, 2018 | 07:50 AM
telcoman's Avatar
Veteran: Army
Trade it in!
Telcoman
g8tor20
Florida G Club
41
May 3, 2006 03:37 PM
ebuy929
Nov 18, 2005 01:39 AM
ebuy929
Oct 28, 2005 12:50 AM
