Pic of under body (front)
Old Apr 11, 2018 | 11:50 AM
celwin's Avatar
Does anyone have a pic of the under body (front part) of the 07-08 G35 sedan? Specifically looking to see the under engine splash shield. I want to see exactly how many screws/bolts it contains. Not push in clips; Just the screw/bolts.
Old Apr 11, 2018 | 12:36 PM
MooseLucifer's Avatar
5 Year Member
blk
Check out the TBW Performance website. He makes aftermarket splash shields and usually has pics of them installed. I say usually because I just looked it up and he does not have pics of them installed, BUT it looks like all RWD 2007-2014 Infiniti G35, G37 & Nissan 370Z use the same piece, so a pic for any of those will do.
Old Apr 11, 2018 | 12:46 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
If it helps, my 2006 coupe uses ALL bolts and zero push in clips. I think there are 18 bolts in total, don't forget the two in the middle.
The aluminum aftermarket ones don't utilize all of the factory bolt holes.
Old Apr 11, 2018 | 12:51 PM
5 Year Member
blk
Weird, my '06 sedan uses all bolts + 1 push-clip right in the center. It's pretty convenient for re-installing, just get that one push clip in, and everything else lines up without any struggle haha.
Old Apr 11, 2018 | 12:53 PM
Hall Stevenson's Avatar
Just from a visual memory, I 'counted' 15 in my head but certainly may have forgotten a few. So 18 or so sounds perfectly reasonable.
Infiniti's online parts store says (12) of one screw and maybe (4) for a different screw (may explain why mine has some missing or some that don't thread in properly).
OP: If you're looking to replace yours or replace missing ones, just take one of the fasteners to any auto parts store. They are generic fasteners and are easily sourced. They are likely sold in packs so get ~20 and you'll be covered for sure.
Old Apr 11, 2018 | 01:10 PM
cleric670's Avatar
BANNED!!!
It's possible I'm missing that clip.
Old Apr 11, 2018 | 02:14 PM
Mine didn't have a fastener or push-clip in the center but I did try and run a fastener into once. It just spun and grabbed nothing ! A push-pin makes sense for helping re-attaching it.
Old Apr 14, 2018 | 04:00 PM
Silversleeper86's Avatar
G35 Sport Sedan 5AT
Would go look at mine, but it's not at the house currently (Turo rental)
Old Apr 14, 2018 | 08:27 PM
G35 NL's Avatar
Part number is 75892-JK500
You see 3 holes in the middle of the panel, the small one is for a clip, the other 2 are bolts
All other holes on the edges are bolts
Old Apr 16, 2018 | 01:50 PM
celwin's Avatar
Thank you. I needed to know because I am going to replace mine and won't be getting under the car until summer; So wanted to know how many bolts I need to buy. I already have a ton of the push in clips
Digilog
Apr 21, 2016 09:40 AM
MyGRide35
Mar 9, 2011 03:25 PM
mikey0129
Archived Sales
Jan 17, 2010 05:39 AM
nyckid
Oct 10, 2003 09:42 AM
