RPM's on highway, yes I know they are usually high
Old Jul 8, 2018 | 06:45 PM
Dozzer's Avatar
Forgot to update this after I checked stuff with the OBD2 scanner.
tested at 80mph indicated by the OBD2, NOT by the speedo. Speedo said about 81-82
RPM at 80. 3275 via the OBD2 and 3400 via cluster.
so I would say my cluster is off and might be moving around some. I have a two hour drive tonight so will be able to test during the drive if it happens again.
Old Jul 9, 2018 | 11:44 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
I gotta say it's odd for a stepper motor to be showing a value HIGHER than what's being transmitted to it, makes me think the stepper motor is fine and that the problem is maybe a fried resistor or something.
Old Jul 10, 2018 | 05:34 PM
stockae92's Avatar
I checked mine yesterday, mine is a 6MT.
its about 76 mph @ 3k rpm
Old Jul 12, 2018 | 04:58 PM
Dozzer's Avatar
Another update. Noticed tach being kind of jumpy when I left work like jumping 100-200 rpms when the rpms wasn’t actually fluctuating at idle.
when I got home I plugged my reader in and it was idling at about 800 but the tach showed 1700. So the stepper motor or what controls it is definitely the problem.
i will be taking it apart at some point to try to fix it I guess before I say it’s fully broken.
Scott Andrew
V36 Engine, Exhaust, Drivetrain & FI
May 25, 2014 09:58 PM
martyball619
Feb 27, 2012 11:25 PM
LakeShore_Slate
Jul 6, 2010 10:49 AM
G35Alex
Apr 12, 2006 10:52 PM
