Where is the AC relay?
Old Sep 1, 2018 | 10:59 AM
CraigVMN's Avatar
Question Where is the AC relay?
I've searched here & Google - I need to locate the AC relay in my 2007 G35x, where the heck is it in the car?
Old Sep 1, 2018 | 11:23 AM
telcoman's Avatar
Veteran: Army
Have you read the HAC chapter in the FSM?
http://www.nicoclub.com/FSM/G37/Sedan/2009/HAC.pdf
I believe what you are looking for is either part of the unified meter and AC Amp or part of the IPDM?
Good luck
Telcoman
Old Sep 1, 2018 | 12:33 PM
CraigVMN's Avatar
Good luck
Telcoman
I'm just looking for where the block is that holds the relay
Old Sep 3, 2018 | 09:15 AM
CraigVMN's Avatar
As it turns out, the relay is built into the IPDM and is not replaceable, outside of replacing the entire IPDM. The compressor clutch is not engaging.
Old Sep 3, 2018 | 02:19 PM
onevq35de's Avatar
You're system is empty. No refrigerant. If it's like my FX, it's a 3 wire plug so you cannot jump it to fill it. I had to get it filled with dye, find the leak, fix the leak and get it filled again. $300 bones later and everythings back to normal.
Old Sep 3, 2018 | 02:49 PM
CraigVMN's Avatar
I filled it with the AC turned up all the way, the clutch never engaged.
Old Sep 3, 2018 | 03:01 PM
onevq35de's Avatar
You filled it yourself? If you did it yourself, you were probably able to just pushed it in due to the leak but it didn't hold....because of the leak. If you took it somewhere and they used the vacuum type equipment, there should be a leak that was detected. If refrigerant is accepted into the system and the clutch doesn't engage, ya need a new compressor. You might be able to get a new clutch though? I never got that far into it.
Old Sep 4, 2018 | 04:41 PM
mugzz's Avatar
Hey CraigVMN,
There’s a seller on eBay that sells the ac clutch for the g35 vqhr engine. I’ve been in what sounds the same situation as yours and went ahead and replaced the clutch myself. Not too difficult to do or special tools required except snap ring pliers. Use the service manual to help you remove the fans, air filter housing, and to loosen up the ac compressor. This solved my ac problem and the compressor has been kicking strong for about two years since I’ve changed the clutch. Hope this helps.
Old Sep 4, 2018 | 05:30 PM
onevq35de's Avatar
Answers not directed towards me but good to know.
Old Apr 9, 2019 | 01:28 PM
tjrob2000's Avatar
I just ran across this searching for why my compressor is not engaging. The FSM shows the relay in the IPDM, but the only relay you can see is the starter relay. I was thinking it must be part of the IPDM and how utterly stupid that would be! Craig, are you certain this is the case as I suspect?
Old Apr 9, 2019 | 03:25 PM
tjrob2000's Avatar
Well, my problem is the compressor, not the IPDM relay. Have 12vdc at the connector, but it is not engaging. Oh well, it is 12 years old with 190k miles on it.
Old Jul 20, 2022 | 02:57 AM
3rtn84's Avatar
G37 Jurney sedan
A/C Relay location !!!!
This prob might be fixed but for everyone else's headache… I have a 2009 G37 but mine was located behind the fuse box on the driver side. You have to remove the plastic panels and push up on the releases and the fuse box will be adjustable just a little. It’s hard to turn around but you can access the A/C relay.
I think it’s the bottom one but they all look the same so…
Old Jul 22, 2022 | 10:57 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Yep, back of the Fuse Box - J/B.
Here's the layout for your 2009 G37 sedan.
Gshroom
Cooling
May 3, 2012 12:48 AM
42N8one
Apr 21, 2011 03:36 PM
