2008 g35 headlight issue/fog light
I have a 2008 g35xs and My driver side headlight went out a while ago (it would flicker at first and then sometimes go on for a little after keep turnign it off and on) and after doing some research i found it was most likely just the ballast. So i got one off amazon and replaced it last week. I thought that fixed it and it was working fine till tonight. I guess it just turned off at some point and now I cant get a thing. No flicker or anything.
SO what now? is it the bulb or a bad ballast? Anything else it could be? Any help would be appreciated.
Also my passenger side fog light is out. Now this was replaced two times in a few months by the body shop (was in an accident) Im thinking this is bad news as its just not the bulb but a bigger electrical problem perhaps. What are the thoughts on this? Cant see it being the bulb blowing two times in that short a time....
no its not flickering really and its not the bulb. Before I changed the ballast it would quickly blink on and eventually after 3 times turning the lights on an off it would go on for a few min then turn off again.
I dont think its the bulb because it worked for a week perfectly fine after I replaced the ballast.
as for the fog light issue Im sure the bulb is out and i can replace it no problem but is the bigger issue something thats causing the bulb to blow out really fast?
dilberts_g
Nov 20, 2019 09:38 PM
WRAH
Jul 10, 2005 10:45 PM
