Annoying Buzz Sound at 1200-1400RPM?? 08G35xs
Old Apr 27, 2019 | 12:12 AM
MING35x's Avatar
G35x Sedan Sport
I have this annoying buzzing sound that occurs whenever I'm coasting through the city at 1200-1400rpm but more on the 1200rpm side. At the beginning, it would happen occasionally so I didn't pay much attention to it. It has reached the point where it always happens whenever I hit the mentioned RPMs. It has also started to buzz when I'm sitting at the stop light! It comes from the driver side but I have no idea if it is an electronic issue or a mechanical one. I know I have a small hole in the exhaust, so I don't know if that is the reason why the buzzing is happening...I have a CBE coming soon.
I have included two video clips where I recorded the buzz sound. Please use the highest quality for the videos in order to hear the sound. YouTube messed the quality of my recordings. It's louder in real life than the videos make it to be.
Any ideas??
Old Apr 27, 2019 | 09:37 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Ok I remember the problem being something like... adhesive used inside the ductwork??? Or something wierd like that. I'm sure someone else will chime in what the problem was
Old Apr 29, 2019 | 12:30 PM
MING35x's Avatar
G35x Sedan Sport
That does sound pretty weird. What ductwork are we talking about? Do you mean they put adhesive in a place where they shouldn't have? Any ideas where can I look?
Anybody else know about this??
Old Apr 29, 2019 | 01:34 PM
cleric670's Avatar
BANNED!!!
Ok here's a link to the TSB I was thinking of, apparently it's particulates in the coolant system that make noise as they pass through the heater core. May or may not be what you're hearing but you should be able to confirm if it's your problem just by listening around for exactly where it's coming from.
https://www.myg37.com/forums/tsb-tec...dash-area.html
Old Apr 30, 2019 | 04:40 PM
MING35x's Avatar
G35x Sedan Sport
Great, I appreciate you looking into this. I will try this out and will follow-up with results.
CerveloR3-SL
Jan 23, 2012 05:43 PM
Thrillryder23
May 9, 2009 09:47 PM
sonofjay
May 28, 2008 01:43 PM
pk3067
Jan 8, 2008 08:37 AM
fldrummer
Sep 9, 2005 03:07 PM
