Alternator connector wire colors
Old May 22, 2019 | 11:13 PM
keith jackson's Avatar
G35
Alternator connector wire colors for a 07 G35
They grey plastic part of the alternator's wiring connector is completely gone. I have a replacement but the wire colors are different, anyone have a picture of the connection's wires so that I can match up which wire goes where? The car is a 2007 G35
Old May 23, 2019 | 01:21 AM
Scorpi0's Avatar
Year and model might help.
Old May 23, 2019 | 07:55 AM
G35
Sorry I forgot to put it but it's a 07 g35
Old May 16, 2023 | 06:23 PM
jwhite89865's Avatar
infiniti g35
same here did u figure out the colors
Old May 17, 2023 | 03:29 AM
Scorpi0's Avatar
Does this help?
Old May 19, 2023 | 10:31 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
B/R = Black/red stripe
W/R - White/red stripe
LG/B - Light green/black stripe
B - black
B/Y - Black/yellow stripe
Old May 19, 2023 | 04:03 PM
jbarnett250's Avatar
Interesting to see a thread about a failed alternator connector. Do many of these alternators or harness side connectors fail? I've been here for years and don't remember seeing many problems with battery charging or alternator failures. I did a search and see a couple of threads but not that much. I joined a Murano forum a couple months ago because I bought a 2010 for my kids. Battery charging and alternator failure and battery failure threads are way more common over there like a couple a week even though it's the same engine (different alternator though). The 2nd gen Murano has a variable voltage charging system that seems to cause problems and I think made mine drain the battery while driving and strand me on the road so I disabled the "smart" function. I see complaints on later model QX forums about disabling the variable charging too. But I've never really seen much about alternator failures or battery charging problems in the 1st gen G35. I don't watch the 2nd gen G35 as closely but watch all the new posts and think I'd see threads about charging problems if they were as common in the G35 as they are in the Murano. I can't figure out why I don't see more here when the Murano seems SO bad.
Old May 20, 2023 | 11:40 AM
cleric670's Avatar
BANNED!!!
It's not common for mystery failures, but normal alternator failures is somewhat common due to the age of these cars though.
Usually it's just the normal "battery light turned on and alternator stopped working" sort of thing that's easy to diagnose and repair.
These alternators are really stout units though, premature failure was definitely not a common problem for these things but most of your 2003-2007 G35 cars are pretty high in miles now though so normal wear/tear failures are definitely a thing.
dlouly76
Aug 7, 2025 01:23 PM
Christopher____
V36 General Tech Questions
May 15, 2008 05:27 PM
hollowch
Mar 30, 2008 06:54 PM
thinhdle
Oct 1, 2007 12:22 PM
