Aftermarket sub and amp install
Old Jun 2, 2019 | 07:34 PM
Kuynichan's Avatar
6MT G35 Sport Sedan w/ Tech Package
Help with Aftermarket sub and amp installation
Hi me and my pops tried to add a amp and sub to my 2007 g35s with the full tech package along with the Bose system. We have everything hooked up but we can’t seem to get any power to the amp, any ideas?
Old Jun 2, 2019 | 07:38 PM
Kuynichan's Avatar
Old Jun 3, 2019 | 02:49 AM
Scorpi0's Avatar
Your blue remote wire should trigger the amp to come on. Looks like u have your wires hooked up correctly.
Check to see if the blue wire is getting power when u turn your stereo on. Make sure the fuse on your amp isnt popped.
Old Jun 3, 2019 | 09:43 PM
Kuynichan's Avatar
So we tried it and still got no power. We tried different terminals and made sure they were tight. Any other clue what it could be?
Old Jun 4, 2019 | 04:00 AM
Scorpi0's Avatar
U sure your blue remote wire is tapped imto the correct wire on that harness?
Does the amp turn on if u touch the blue wire to the Red main power cable?
Old Jun 4, 2019 | 11:41 AM
Kuynichan's Avatar
I believe all wires are connected to the right ones on the harness, but we're not sure if maybe the wires are too small to make a connection. Haven't tried connecting the blue wire to the main power cable.
Old Jun 4, 2019 | 07:17 PM
Scorpi0's Avatar
Jump the blue remote terminal to the red power cable terminal on the amp. The amp should turn on that way. If it doesnt, then the amp is probably busted.
Old Jun 4, 2019 | 08:55 PM
.cakestar's Avatar
use a multimeter to check. you can easily check if your amp is getting power and then double check the voltage on that trigger wire
Old Jun 8, 2019 | 01:45 PM
Kuynichan's Avatar
Yeah so I tried the rem wire with the power wire and nothing worked I believe the amp might be done after this, but thanks for the help!
Old Jun 8, 2019 | 01:52 PM
Urbanengineer's Avatar
Sounds like you should get it tested yes.
4mermarine
May 27, 2018 02:14 AM
ImportPartsPro
Suspension-Vendor
96
Sep 2, 2015 12:31 PM
Thunderaan
Jul 22, 2015 07:40 PM
KingJames
Oct 27, 2005 05:14 PM
