Dead alternator
Old Jul 20, 2019 | 02:07 AM
terrasmak's Avatar
G Sedan
Dead alternator
I guess my power steering leak killed it, slow leak for a while , major leak after a couple repair attempts. Disturbing part, that nice little battery thing on the gauge cluster never came on. Car died on the freeway off ramp with my wife in it. Fun part, getting it back into neutral for a quick tow off the road, that stupid little cover panel can't be popped off with a key.
Got the car car towed home , charged the battery and duplicated the result in my driveway. No battery light, and charges at 13V , not enough to sustain running (especially with the AC running ) but enough to keep the lidiot light from coming on .
Hopefully i I will have a reliable car soon. Heater hoses are also on the way
Old Jul 20, 2019 | 09:50 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
There is a tool in the trunk to pop that little trim cover off for the neutral release.
Are you certain the battery light on the dash is functioning at all? Does it turn on during a lamp test?
Old Jul 20, 2019 | 12:39 PM
terrasmak's Avatar
G Sedan
Functions as normal during lights test, was the first thing I did when I charged the battery. Then as mentioned, I duplicated it with the light not coming in.
I believe they want you to pry it with the back side of the 10mm wrench, please try it. I did when I got the toe hook out.
Old Aug 9, 2019 | 05:46 PM
scumbagsleeper's Avatar
1990 Mustang GT - 351W Lightning bored/stroked 383CI TFS heads 78mm Turbonetics huricane
That's weird. I've never heard of a car dying with 13v alternator output. Let us know what happens when you replace it.
Old Aug 10, 2019 | 01:16 PM
terrasmak's Avatar
G Sedan
Been driving without issue for a few weeks now, current voltage is 14.2 volts as required.
Old Aug 20, 2019 | 07:38 AM
Joenavy85's Avatar
G35x Base
My voltage sits right at 13v when I've been driving for a while. When I first start it up it goes to 14.2v and after about 5 minutes drops down to 13v.
Edit: I threw the serpentine belt off my Jeep a few years back due to a fried tensioner pully, it kept running long enough to get to a friends house (about 3 miles), was down to around 11.5v at that point, and that was with the air/heat on full blast.
red35
Feb 17, 2023 09:48 AM
tjrob2000
Jan 29, 2019 04:18 PM
Cashiz89
Jun 20, 2018 02:27 PM
Ottovq35
Aug 28, 2017 10:25 AM
divito
Jun 9, 2014 10:01 AM
