Window problem
Window problem
So I’ve been working on my car lately and doing a full wrap on it. Today when i was doing the driver door I disassembled and reassemble the door panel to get the door handle off. After i put everything back together, only my driver window works now. None of the other windows work and are stuck halfway. They don’t work from the switch on the driver panel or any of the switches on their own panel. Anyone have any suggestions or help to offer ? I can’t figure it out. Thank you
Unplug the switch again and see if you bent any of the pins.
You had the battery disconnected when you unplugged it the first time correct? If not you might have screwed up something in the BCM.
trunks333
Aug 2, 2010 10:39 AM
aszatk01
Jun 15, 2005 02:42 PM
