HomeLink Rear View Mirror from newer model Nissan/Infiniti?
Old Dec 9, 2019 | 10:15 PM
dx_g35's Avatar
G35 Sedan Sport
Hi Guys - I just found out my 2007 G35 sendan homelink mirror doesn't work with my new place, which has the latest Liftmaster Security + 2.0. I would like to program the garage opener to the mirror and not have a remote to mess with.
So question is, will a newer model nissan or infinity mirror with homelink be able to swap directly in a 2007 G35? Or will I need some kind of modifications to the mount and wiring?
Old Dec 10, 2019 | 12:30 PM
909's Avatar
909
Your mom's boyfriend
Does your opener have MyQ technology aka wifi ?
Just use your phone bro.
Old Dec 10, 2019 | 02:14 PM
dx_g35's Avatar
G35 Sedan Sport
yes, MyQ could be a solution, but I'm just a renter and want to make it the lease intrusive and not bother my landlord.
They gave me a remote, so they've done their part of giving me access. So setting it up with the homelink in my car is just something for me and don't want to involve them.
That's why I figure, if I get a newer updated mirror with homelink, this should get me to where I want to be. So does anyone know if I can just get a newer mirror and install it?
Old Dec 10, 2019 | 03:12 PM
MikeG35Coupe's Avatar
20 Year Member
One owner 2004 G35 Coupe 6MT
Just curious how you know it's definitely not compatible? I ran into a similar issue with my '04 and a Homelink light switch and discovered that there was a Homelink-related change to the mirrors somewhere around 2006. I'm surprised your're having an issue programming your '07. I had planned on upgrading to a newer mirror too, but since my ancient garage door opener works fine with it I sort of gave up. I would think as long as the connector and wiring are compatible you could upgrade to a newer one. You might even be able to re-wire one that has a different connector, as long as you know what each wire is for.
Having to take out and unlock my phone to open the door would annoy me.
Old Dec 10, 2019 | 05:34 PM
dx_g35's Avatar
G35 Sedan Sport
@Mike - so with the current remote, I tried to program it to my car, without any luck, and even tried to clear out all programming by holding down the two most outer buttons and starting again. I know my homelink works because I was able to program my previous place which also had a Liftmaster unit with the purple learn button.(older version?)
So then, I tested the current remote by programming it to my friend's 2016 E series Mercedes and that worked. So that's why I'm guessing I need a newer version of the homelink mirror from one of the newer model Nissan/Infiniti
Old Dec 10, 2019 | 11:27 PM
909's Avatar
909
Most people have cell phone holders in their car so either way you're either pressing a button on your phone, garage door opener, or rear view mirror .
Just depends on how much you want to spend .
OP my guess is the unit is self contained and the wires just feed power .
You can always check https://www.nicoclub.com/FSM/G35/Sedan/2007_G35_Sedan/ .
If you can't program your existing one, and really want to swap it , try to find a dealer that accepts returns on new electronics in case it doesn't work.
Don't get stuck with it bro.
kewltea
Jun 30, 2009 10:38 PM
deniance
Jan 4, 2009 09:34 PM
Borna
V36 General Tech Questions
12
Jun 6, 2008 12:48 PM
dunglan7
Feb 14, 2007 08:43 AM
