Location of mass air flow sensor
Old Dec 27, 2019 | 05:52 PM
wjdthird's Avatar
G35x
Hi all,
g35x 2008 check engine light on code P0171 Replace MAF. Can someone tell me where this is I have googled and you tubed but unable to find this pic. It appears as if there are two of these running off each air intake but not sure. I searched forums and the images have been deleted.
thank you!
Old Dec 28, 2019 | 01:15 AM
scumbagsleeper's Avatar
1990 Mustang GT - 351W Lightning bored/stroked 383CI TFS heads 78mm Turbonetics huricane
Old Dec 28, 2019 | 07:48 AM
wjdthird's Avatar
G35x
Thank you my friend
Old Dec 28, 2019 | 11:26 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
P0171 isn't a MAF code, it's just saying that bank 1 is running lean. It could be a LOT of things so start troubleshooting rather than throwing parts at the car.
Old Dec 29, 2019 | 09:19 AM
wjdthird's Avatar
G35x
Hi Cleric,
Thanks for your input ! I am not a car mechanic a computer tech by trade..I rely on google and auto zone. I am guessing it is MAF as i have 80k on thisG35 and have never cleaned the MAF sensors..I wil clean these first. The autozone person thought it may be a vacum issue..Do you have any suggestions on next step if cleaning the sensor fails?..Thanks for your time !
Old Dec 29, 2019 | 03:40 PM
cleric670's Avatar
BANNED!!!
It usually is a vacuum leak, real-time scanning the O2 sensor data will probably tell you a lot. Look at your short-term fuel trim and see how far off it is, it starts to throw that code when it has to add more than +25% fuel on that bank.
With the engine on and the vehicle in park stop the throttle wide open is there a bit of a lag? If so then it is almost definitely a vacuum leak. Check to make sure the intake pipes are tight and that there is no rips or tears in the accordion flexible section. Also check your PCV hoses to make sure that they are tight on the fittings take out the PCV valve and shake it to make sure it rattles. If any of those hoses are loose and can be turned easily then they are sucking air. Also check the brake booster line.
Old Dec 29, 2019 | 04:23 PM
wjdthird's Avatar
G35x
That’s great info thank you very much !!
thelewal
Mar 3, 2014 08:52 PM
DGrantG
Aug 29, 2012 08:33 PM
Geeed-UP
Oct 18, 2007 10:32 PM
jcarlson9
Intake & Exhaust
Oct 26, 2005 10:34 PM
Gsedan35
32
Jan 18, 2005 11:52 PM
