That's a great deal on a seat. The curtain bag and the control module from a 07-10 is what fits it.
Thank you! I was shocked it was that cheap to be honest. Especially in the great condition it is in! I will probably just send in my module to get reset I guess. Trying to find a write up or video to help me with removing that!
Well in searching for the airbag control module, I managed to somehow mess up the car realizing it is in park. I put everything back normally and the car says P shift with an arrow. Not good. The button on the shifter does not full disengage when in park, and I can move it from park without pushing down the button. Or using the brakes. I removed everything again, but something seems off with the shift lock. I can manually move the piece on the side when NOT in park and push it up and then that will fool the car to thinking it is in park. This should happen normally when IN park. I am so lost and annoyed !
The plastic white piece does not seem to be fully engaging and moving up as it should on its own. Once In park, I can not manually move that up any further. If in N, I can move that white piece all the way up, which shuts off the "P" alarm. Maybe lubricant? Condesnsed air? It sucks that this is an issue when I hardly have done anything so far to even cause it lol
It sounds like some thing at the bottom of the lever has fallen out or turned at the base of the lever. I think the SRS computer is at the back of the console but remember that the back seat a/c vents run through it so likely they're in the way.
Not sure if you figured it out already but the "airbag computer" is called the "SRS diagnostic control module" and it's located below the center console. On every startup it does a self-test of the system and if there are any errors detected it sends them via CAN to the ECM which will flash the SRS light.
There are shops on eBay and elsewhere that claim they can reset the module, I'm not sure exactly what this entails but I'm guessing it's a reflash of an EPROM or something because they are normally a one-time-use item that is replaced once triggered. Personally I would just buy a used one from eBay from a reputable vendor.
There's pictures of locations for everything in the FSM under the SRS section.
Module has been sent out for repair/reset. Just came across something else I might need. What is this and where does it go? https://extreme-auto-parts.com/infin...13-k8830-eg20a Hoping it was in the door or seat that I replaced already
