Waterpump
Old Jan 16, 2020 | 07:08 AM
909's Avatar
909
Your mom's boyfriend
Waterpump
Who's done theirs and how difficult was it .
Thanks brothers.
Old Jan 16, 2020 | 07:15 AM
Scorpi0's Avatar
Sup man
Old Jan 16, 2020 | 08:54 AM
scumbagsleeper's Avatar
1990 Mustang GT - 351W Lightning bored/stroked 383CI TFS heads 78mm Turbonetics huricane
Big job, not cheap if you have a shop do it.
Old Jan 16, 2020 | 12:29 PM
Joenavy85's Avatar
G35x Base
If you do it yourself you might as well replace the timing chain/tensioners and the oil galley gasket while you've got the front of the car off.
Old Jan 16, 2020 | 03:24 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Pretty easy, just watch a couple videos along with the FSM so you know which way to put slack on the chain. Also, pull the spark plugs so it doesn't try to crank back on the chain, if you screw up and jump a tooth on the timing chain then you have to disassemble the front of the engine to fix it.
Old Jan 16, 2020 | 05:42 PM
coffeysm's Avatar
What he said. This happened to me a few years ago and I ended up having to pull the front cover off.
Thanhnguyening
Oct 12, 2014 02:27 PM
coffeysm
Dec 5, 2013 01:49 PM
nicoG35
Apr 18, 2013 12:34 PM
