Just installed a sub
Old May 18, 2020 | 02:18 AM
909's Avatar
909
Your mom's boyfriend
Infiniti engineers are amazing.
Install took less than an hour.
Sounds great.
Just realized how much the stock bose system lacks low end.
Pics coming
Old May 20, 2020 | 03:37 PM
dx_g35's Avatar
G35 Sedan Sport
pics and some details please
Old May 20, 2020 | 05:38 PM
909's Avatar
909
Soon homie
Pics cooming
Old Jun 14, 2020 | 09:47 PM
909's Avatar
909
Sorry for the delay broski . Working hard, haven't had time to take pics bro.
Basically I bought a used ACTIVE sub locally for $20 .
It's one of those bazooka tubes.
It's 300 Watts with a built in AMP.
Then I bought a new wire kit for $30 .
So my total cost was $50 .
My trunk now rattles, so do the side mirrors, and the rear view mirror rattles too .... if I WANT IT TO .
If you search your local classifieds, you'll find deals like these all day.
I went with a bazooka because it was the smallest option possible.
It barely takes up any space.
I still feel like I still have a full trunk.
Plus it was dirt cheap.
For it's size, it pumps out wayyyy more bass than I expected.
For some people who are used to loud systems, it's probably under powered.
But I'm a club DJ , and for my daily driver, it's more than enough.
It's loud enough to give you a headache if you want it to.
The install is just a standard install.
It was really easy.
Remove the windshield cowl.
Remove the battery box.
Pull out the fuse box.
Just 1 + power wire from the battery.
Behind the battery, there is pre drilled hole. With a rubber plug.
Infiniti thought of everything. Their engineers are so smart.
I stabbed a long screwdriver through the hole - to break through the insulation
Then fed the power wire through that hole and to the trunk.
That was literally the hardest part . And it wasn't hard at all.
For the remote power you'll see a light grey wire in the middle brown connector on your trunk preamp.
For the audio in, just split the audio out from your bluetooth / tablet / phone / aux in / device and feed it to your trunk.
For the negative, just ground it literally anywhere in your trunk.
It's literally 3-4 wires.
The install took less than an hour.
$50 later, a bumping system.
Do it bro.
Old Jun 14, 2020 | 09:51 PM
909's Avatar
909
Old Jun 15, 2020 | 06:52 AM
Scorpi0's Avatar
I have a 10” bazooka tube in my trunk too. It actually puts out good, clean bass. I also went with it because it fits into the deep trunk cubby area perfectly. I have mine wired to an amp though.
Old Jun 15, 2020 | 07:13 AM
909's Avatar
909
Broski ... Your 10 inches is bigger than mine 8 inches ( no homo ) . Fits perfectly under our ski pass through doesnt it. I bought tie down straps at the dollar store and secured it to the backseat frame. My wire is oversized so if I ever need more power (doubt it ) an upgrade would literally take 30 seconds to swap out. The bass is already clean and tight.
Listen to this mix I made on your Bazooka bro. Your car will pound. Drum and Bass / Jungle is my guilty pleasure :
https://drive.google.com/file/d/1-5b...w?usp=drivesdk
Old Jun 18, 2020 | 05:18 PM
dx_g35's Avatar
G35 Sedan Sport
bazooka.....ok, no need for pics....hahaha
Old Jun 18, 2020 | 08:19 PM
Scorpi0's Avatar
Ive had many women compliment my bazooka
Old Jun 19, 2020 | 06:27 AM
909's Avatar
909
Talking
Same here. Always performs . No troublshooting
jdubin94
Feb 2, 2012 08:22 AM
faiz23
Jul 25, 2011 12:45 PM
BocaCoupe
Mar 20, 2007 02:30 PM
