2007 infiniti g35x wont start,wont crank,
Old Dec 15, 2020 | 10:53 PM
Shawn paul's Avatar
g35x
I can play the radio lights are on just wont start have been having this issue for awhile last time i changed starter the car was running for a few days (like 3 weeks ago)then it did it again changed battery wasnt work so for a week i laid of then i check fuses it was the igition switch 30amp car crank radio up turns off find everything just needed mass air flow sensor now today i try to get in it just tell me push my foot on brake and start up but when i do that everything turns off no click or anything dash doesnt light up to see speedometer anybody help please?
Old Dec 16, 2020 | 07:26 AM
telcoman's Avatar
Veteran: Army
You most likely have one or more dead cells in your battery?
Test your battery! Use a battery hydrometer.
charge battery and test cells again to make sure all 6 cells reach a full charge.
If not return and exchange the battery.
I always purchase my replacement battery's at my local dealer.
Use your multi meter to measure the output voltage from you alternator when you finally get your vehicle running. Should be 14.4 volts.
It is also possible that you have a defective starter? Where did you purchase it? There is a lot of cheap shyt being sold to unsuspecting car owners looking for a bargain.
Reading your post lacking punctuation can give one a headache, but if a 30amp fuse blew you have a problem.
Dis anything get wet?
Good luck
Old Dec 16, 2020 | 08:30 AM
Joenavy85's Avatar
G35x Base
Had an issue a few weeks back where when I would try to start it up it would turn everything on for about a quarter of a second, and then black, nothing, no power at all. So I picked up a new battery, tore into the car to pull the old battery, when to disconnect it, turns out I was an idiot when I added a power wire onto the positive terminal and it had come loose, tightened it up, all was good, and now I have a spare battery. Check your connections, and then track down the grounding strap for the engine to ensure it isn't corroded through or loose.
Old Dec 17, 2020 | 06:53 AM
Mr.GEE's Avatar
20 Year Member
There is a switch at the top of the brake pedal assembly. It allows power to the starter when you push the start bottom and depress the brake. Check to make sure the switch is working and it has not come loose.
Old Dec 18, 2020 | 08:11 AM
Joenavy85's Avatar
G35x Base
This would definitely prevent it from starting, but if everything is going dark it's likely something different.
Old Dec 18, 2020 | 01:02 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Everything going dark is usually just a dead battery.
Juan Ortiz
Aug 4, 2024 11:25 AM
Jaay210
May 16, 2020 04:20 PM
Carlos0221
Dec 21, 2019 01:46 PM
Car
Jul 6, 2015 02:06 AM
cbrseadude
Oct 9, 2014 11:01 AM
