'07 G35S fuel damper replacement
Old Nov 8, 2021 | 02:46 AM
Cabrito's Avatar
07 G35S 6MT
My fuel damper is leaking so will be replacing it. It comes with a hard line
attached that connects to the fuel pipe on the passenger side near where
the exhaust manifold meets the cat.
Will I need to have something handy fo plug the fuel line from the gas tank
since this break will likely be below the tank? Or will the flow be limited due
to the fuel pump being in the path?
Thanks.
Old Nov 8, 2021 | 10:41 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Just pull the fuel pump relay and crank the engine over and let it stall out, then you won't have any fuel pressure on the line.
Fuel doesn't come out of the tank unless it's pumped out, gravity won't pull it out and it can't siphon through the pump.
Old Nov 5, 2022 | 05:11 PM
treacherous's Avatar
20 Year Member
G35x
I noticed the smallest of gas smells in cabin... pulled the engine cover and noticed residue here with strong gas smell on passenger side fuel dampener. I need to check my docs to locate the fuel pump relay.
Getting part on order to install
Old Nov 5, 2022 | 05:45 PM
20 Year Member
G35x
Looks like fuel pump relay is in this area at #41 in Box #1
I may just go with rag and eye protection.. doesn't look like much fuel came out in the Youtube video.
https://fuse-box.info/infiniti/infin...ses-and-relays
Old Nov 6, 2022 | 05:53 PM
cleric670's Avatar
BANNED!!!
If you pull the relay then crank the engine for a couple seconds it relieves all the pressure in the system.
Old Nov 7, 2022 | 11:10 AM
20 Year Member
G35x
Just trying to minimize the trim I need to remove and save a little time... doesn't look like I can get into that relay box easily without removing a bunch of the plastics around the battery.
Old Nov 11, 2022 | 06:25 PM
20 Year Member
G35x
I'm gonna see if the cheap o-ring fix addresses issue first before swapping entire line. It is barely leaking at all at this point... I see residue but don't see droplets but can smell it some.
https://www.z1motorsports.com/fuel-r...g-p-24693.html
Old Nov 13, 2022 | 11:42 AM
cleric670's Avatar
BANNED!!!
I've never done a fuel damper on the HR, are they that difficult to reach? DE engine only has one and it's right out in the open, however it's on the opposite side of the single throttle body so there isn't anything in the way.
Old Nov 13, 2022 | 11:51 AM
cleric670's Avatar
BANNED!!!
Also, o-rings like that typically wear out from ethanol in the gas.
Most of the non flex fuel engines use nitrile because they're cheap.
Newer engine o-rings are mostly flourosilicone (however you spell that) or viton, they're used on all your modern flex fuel cars that can handle e85.
Viton is always my o-ring of choice for anything on an engine, AC systems, fuel systems (gas, ethanol, methanol, diesel). They're EXTREMELY resistant to everything, but they have a higher durometer rating than nitrile so they're a lot more difficult to install because they're so stiff.
I'm sure those ones Z1 are selling are NBR nitrile, those are your typical black colored gas resistant orings. They'll work fine for another 100k miles and are definitely a lot easier to install.
Old Nov 17, 2022 | 05:40 PM
20 Year Member
G35x
Easy o-ring swap.... just kept a few extra rags around damper when pulling out and only a little bit of gas sprayed into rags.
So far no further leaks.
vkmotorsports
Sep 6, 2021 03:16 PM
calvinc
Sep 24, 2019 08:43 PM
aroundincircles
Oct 21, 2015 04:47 PM
Mr_pharmD
Engine - Power Adders
Dec 22, 2010 08:03 PM
Gian124
22
Mar 13, 2010 02:00 AM
