Another water Leak Thread...
Old Apr 6, 2022 | 02:37 PM
tgodon13's Avatar
G35x
2007 G35x - Water leaking in on passenger side. A few months ago I removed sunroof drain in the firewall, cleaned and tested. Water flowed out great. Since then the car has still been leaking quite a bit on the same side. I sealed the rubber boot where the wiring harness goes through the firewall. It rained last night and again I had water. I sprayed the car windshield with a hose this morning and checked for water, none coming in. I then sprayed the roof and water is coming in. I removed the tube and grommet from the firewall again and routed it into a bucket. Sprayed the roof again and water was flowing out the drain tube, but was also still coming down the very front corner under the dash just ahead of the wiring block that is under the passenger side kick panel. I cannot figure out where this water is coming from. Any ideas and assistance in how to fix this is appreciated. It is raining again and we don't really use the car too much so I have covered it with a tarp until I can work on it again.
Old Apr 8, 2022 | 07:46 PM
treacherous's Avatar
20 Year Member
G35x
Drain line detached from sunroof?
I didn't have that issue... mine was firewall and put in alternate drain line
https://g35driver.com/forums/g35-sed...ml#post7206990
You may need to drop headliner to know for sure
Old Apr 20, 2022 | 11:48 AM
tgodon13's Avatar
G35x
If I pour water into the sunroof drain it flows well and exits out under the car. Headliner is dry. Only floor getting wet and it is trickling in at the far right corner under the dash where the firewall meets the side of the car.
Old Apr 20, 2022 | 01:33 PM
909's Avatar
909
Your mom's boyfriend
I keep hearing stories like this and never want to open my sunroof ever again.
The most common source of the problem should be coming from your sunroof down.
Old Apr 20, 2022 | 03:14 PM
Triton3.5's Avatar
Could it be coming from the battery tray? the area under, or behind the battery?
Old Apr 23, 2022 | 02:12 PM
20 Year Member
G35x
+1.. is water backing up around the battery?
wfhenderson
Nov 27, 2022 11:43 AM
BobFar2021
Oct 22, 2021 12:25 PM
hkjai
Jan 16, 2014 12:07 AM
xShadowx
Dec 4, 2011 08:51 PM
RJP6
Apr 27, 2005 05:54 PM
