2008 g35 sedan tsb question
Old Aug 16, 2022 | 10:05 PM
GasKing's Avatar
G35 sedan
Hesitation/bogging and stalls at 1k rpm
Hey everyone. I recently purchased a 2008 g35 sedan from a private party. After a week, I started noticing that the car would hesitate and stall right at 1k rpm if not given enough gas. Initially I thought it just need some tlc so I cleaned the TB/MAF/reset the idle, changed the spark plugs, battery, and used some fuel cleaner. After researching the forum I believe it’s due to TSB itb11-018, which requires a ecm reprogram. My question is, is the dealership the only option to have it reprogrammed? They’re charging a $200 diagnostic fee plus cost of programming if needed. Anyone know if I could get a reflash like uprev to fix it? My isssue is exactly like this video. https://www.youtube.com/watch?v=89abNzb1k7o
Recap: engine hesitates/stalls at 1k rpm. Issue only happens after car is warm and in 1st gear. Typically when I give a little gas pulling into a parking spot or from a complete stop. No other issues. Car runs prefect otherwise. I can replicate the issue if I leave the car in first, hold the brakes with one foot, and rev it up to 1k rpm.
Old Aug 19, 2022 | 04:29 AM
909's Avatar
909
Your mom's boyfriend
This is a common issue. Mine went away.
Has the car been sitting. Have you gone on a long highway trip for hours. Try the pedal dance and re-learn.
Old Aug 19, 2022 | 09:13 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
FSM section EC - Engine Controls. Idle air volume recalibration under the "basic service procedures" step. This needs to be done anytime you clean intake stuff like the throttle bodies and sometimes you need to do it a couple times to "get a good one". Alternately you can use an OBD2 bluetooth adapter and the Nissan Datascan 3 app for your smartphone. That lets you view the status of the power relay to make sure the system CAN be recalibrated as well as just requiring the single push of a button to initiate rather than the pedal dance method.
However the TSB was mostly just due to a hesitation, it's INCREDIBLY uncommon for it to stall out unless you have other problems and I would suspect a vacuum leak.
As for the reprogramming, yes an UpRev tune would correct this issue as well.
Old Aug 20, 2022 | 02:17 PM
GasKing's Avatar
G35 sedan
thanks for the reply. No it hasn’t been sitting long. I drove it on a ~100 miles trip the first weekend it got it. I’ll try the pedal relearn again.
Old Aug 20, 2022 | 02:38 PM
GasKing's Avatar
G35 sedan
thank you. I didn’t know that the stalling was uncommon and that the tb reset takes a couple of tries. I’ll try it again tonight.
Old Aug 20, 2022 | 09:11 PM
treacherous's Avatar
20 Year Member
G35x
I lived through a lot of TSBs in 2007-2008 for my '07.
One specifically I experienced was a hot soak idle where the car would start revving up and down at low idle after for example a stop light. Also the 2007 models had a very sensitive accel pedal... this was tuned down as well with TSB.. Undoubtedly some are still out there that aren't flashed. Ordered mine 12/2006 and took delivery 3/2007
Cruise control surge, replacement FOBs, other engine flashes, etc...
I don't think about it much anymore... she is "old school"
Toyota reliable these days
Old Aug 23, 2022 | 07:01 PM
Erick88's Avatar
Hr sedan
Im scheduled to get this TSB itb11-018 tomorrow at the dealer due to same issue, will the update tuned down my acceleration sensitivity? if so I might reconsider 🤔
Old Aug 24, 2022 | 09:33 PM
cleric670's Avatar
BANNED!!!
I've never heard of anyone complain about changes to the APP ramp after that TSB. Normally they're singing praise about how the car functions normally.
Old Aug 25, 2022 | 12:41 PM
Erick88's Avatar
Hr sedan
Ok awesome I was afraid I would loss pedal sensitivity with the update, I guess this is my only option left to try for the 1k hesitation since I have checked everything else oil pressure/ retarders ohms good/ fuel pressure/ coil and sparkplugs, will give it a try
gnoob35
Dec 7, 2016 02:01 AM
sloAZZxsSedan
Jan 22, 2016 11:16 AM
Rhinoe
Apr 6, 2015 09:55 AM
bhdot
Jul 16, 2012 09:38 PM
highend
Sep 14, 2008 12:44 PM
