2007 Infiniti g35x coil wire
Old Jun 18, 2023 | 09:43 PM
gace313's Avatar
2007 Infiniti g35x
I was trying to cut the ignition coil wire and I was wondering which wire was the correct one to cut or if there is a diagram
Old Jun 19, 2023 | 10:37 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
What exactly do you mean, there is no ignition coil on these cars. Do you mean COIL PACK? There are six of them.
Old Jun 19, 2023 | 11:44 AM
gace313's Avatar
2007 Infiniti g35x
yes the coil packs where is the wire that connects all of them that I can cut
Old Jun 19, 2023 | 12:41 PM
cleric670's Avatar
BANNED!!!
For the HR engine coil signal/transistor it's ECM pins 11 grey wire, 12 blue wire, 15 violet wire, 16 green wire, 19 sky blue wire, and 20 yellow wire for the ignition coils. They all use individual wires.
Coil primary side is IPDM fuse 50 (15 amp) which is then goes through the ECM relay, out on pin 53 white wire to the coil packs, intake cam solenoids, exhaust cam retarders, and EVAP solenoid.
What exactly are you trying to do? Why do you need to cut this wire?
Old Jun 19, 2023 | 12:44 PM
gace313's Avatar
2007 Infiniti g35x
Im trying to add a hotlicks flamethrower kit and it says to cut the ignition coil wire and Add the wire that they provide between the 2 so if you can check for me what exact wire to cut please and thank you.
Old Jun 20, 2023 | 11:16 AM
cleric670's Avatar
BANNED!!!
You want the IPDM one off the ECM relay, white wire, pin 53.
Old Jun 24, 2023 | 09:42 AM
cleric670's Avatar
BANNED!!!
Here's a picture of the IPDM harness.
Old Jun 24, 2023 | 09:44 AM
cleric670's Avatar
BANNED!!!
Most people just trace that white wire in the coil pack harness up a little ways past where they all join (factory splices off to each coil pack) then snip it there. It's a lot easier than taking the IPDM out but either would work.
Old Jan 8, 2025 | 10:08 PM
gace313's Avatar
2007 Infiniti g35x
I was trying to install the hotlicks flame kit and I was trying to know if there is a certain place to put the ground wire in the trunk because I put it on one of the screws where there are ground cables and when I use the flames the car shows at check and the shifting lights disappear from the dash and also shows the amber key sign
Ant2021
Aug 13, 2019 07:50 PM
ProfanityPete
Jan 30, 2009 12:56 AM
hollowch
Mar 30, 2008 06:54 PM
SFLG35
Nov 16, 2007 10:40 PM
yoyopol2000
Nov 14, 2004 12:49 PM
