why is the bleeder hose clamp so ****ing hard to get on???
Old Jun 8, 2024 | 04:51 PM
Darelle700's Avatar
g355
i put it back on plenty before with no issues now this mother****ing clamp act like it barley fits the hose
Old Jun 8, 2024 | 06:31 PM
treacherous's Avatar
20 Year Member
G35x
Bleeder for?
Old Jun 10, 2024 | 05:45 PM
99zx2turd's Avatar
coolant, i'd guess. i would just delete that stupid plastic connector and run a straight metal elbow or, if you really want to have a bleeder still, a metal aftermarket bleeder piece.
cooling system on this car must've been designed by some sick fu**... it's that bad.
Old Jun 11, 2024 | 06:47 PM
jbarnett250's Avatar
Z1 has a nice aluminum one.
https://www.z1motorsports.com/z1-pro...b6ae8c10d4e5c5
But seems like it would be just has hard to get a clamp over that one as the standard plastic one. I have to use a spill free funnel to bleed the system or I always end up with air pockets even if I use the bleeder. My kid has a Murano (same VQ35DE) and it doesn't come with a bleeder valve installed in the line. The FSM tells you to disconnect at the firewall to burp it. Yeah.... right. Not in that transverse engine crossover engine compartment. Can't even see it back there much less burp it there.
Old Jun 11, 2024 | 08:22 PM
20 Year Member
G35x
I put those Z1 bleeders on both sides of mine when I replace all the coolant hoses around the motor years back
Easy bleed with front on ramps and leveraging the two Z1 bleeders
https://g35driver.com/forums/v36-eng...ml#post7197433
LI-G35Driver
Oct 1, 2022 10:05 AM
shurur
Dec 31, 2021 07:22 PM
Lil_Spanish
Jan 19, 2020 11:32 PM
bluestacy04
Sep 29, 2007 02:46 PM
FLFIRE
Mar 20, 2005 02:00 AM
