G37 Coupe V36 2008+ Discussion about the G37 Coupe
Help - Radiator fan always on
Old May 23, 2016 | 12:26 PM
chrisg37's Avatar
2008 G35 S 169,000 miles
As above I will start the car when cold the radiator fan runs, it will shut off from time to time but comes back on.
Anyone else have this issue?
I am not sure what to look at. I have read to check for low coolant, air in the system or a bad relay?
Old May 24, 2016 | 07:54 AM
infinitidude's Avatar
Chris, the only time I've seen this on a V36 model was when it had aftermarket cooling fans installed. Not saying this is the case, but if you have aftermarket cooling fans I would start there first.
jbmw002
Nov 28, 2016 10:57 AM
edwinisdumb15
SOCAL Meetings & Events
Sep 2, 2016 03:31 PM
Jgonzalez
Mar 3, 2016 12:20 AM
SS G35
Feb 29, 2016 06:23 PM
Jiggs1219
Feb 25, 2016 08:30 AM
