Will Arc strut bar clear w/ 5/16 spacer, Mrev2 and 350z cover?
Old Mar 20, 2007 | 12:34 PM
jonnylaw's Avatar
Anyone know If the Arc can clear a 5/16 spacer, mrev2, and 350 z engine cover/or no engine cover w/out rubbing or pushing the hood up?
Old Mar 20, 2007 | 01:47 PM
God|ZIlla168's Avatar
yes it will fit
Old Mar 20, 2007 | 01:50 PM
jonnylaw's Avatar
Are there any major modifications that have to be done when installing a strut bar and brace on a G--since out cars do not have struts stock? (any cutting or drilling required?) Is it possible to later take out the arc strut bar and have everything look the same pre-install (or does installation of the strut bar and frame cause permanent indication of install)?
Old Mar 20, 2007 | 01:56 PM
izmir41500's Avatar
G35driver Addict
no modifications necessary. a simple DIY, just make sure you have the right tools and socket extension. you use stock nuts for the mounting plate. check out richie's front strut bar. it's an aluminum arc replica. they have instructions also.
Old Mar 20, 2007 | 02:33 PM
ttrank's Avatar
Grocery getter
My Richie one clears that same setup.
Old Mar 21, 2007 | 12:10 AM
jonnylaw's Avatar
^^Wow TTrank your engine bay is hot!^^ Were you able to use the bolts and fasteners that came on the stock engine cover on the z style engine cover, or did you have to order seperate ones?
Old Mar 27, 2007 | 03:26 AM
.cakestar's Avatar
Will this same setup still work with tien flex's and EDFC?
Old Mar 27, 2007 | 11:57 PM
.cakestar's Avatar
anyone? kuz im looking to get this setup with the ARC bar and tein's but i have heard that it wont clear with coilovers and the EDFC. advice pls
Old Apr 5, 2007 | 11:36 PM
richie's Avatar
It'll work with the EDFC - you just have to disconnect the wire harness, install the plate then put the wire harness back.
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Picture Share
Feb 4, 2018 12:41 PM
prinny
Nov 22, 2015 11:07 PM
