AT automatic transmission dipstick location
Old Apr 18, 2007 | 08:57 PM
g035sedan's Avatar
Where in the heck is it? I have 2005 automatic. It's not anywhere in the owners manual. It specifies every other fluid location but that.
Old Apr 18, 2007 | 09:12 PM
Nismo G's Avatar
If you are looking at the engine from head on look to the back left of the plenum. It is tucked in that corner just to the right of the battery "casing". It requires i believe a 10 or 15 mm socket to take the bolt off that holds the dipstick in place.
-Sean
Old Apr 18, 2007 | 09:27 PM
g035sedan's Avatar
thanks.. i found this..
Behind the engine, slightly to towards the passenger's side, near the firewall. See the tranny tube sticking up. Remove the 10mm bolt securing the dipstick.
Make sure you use factory Nissan fluid, nothing else.
Old Apr 18, 2007 | 09:29 PM
Augy's Avatar
its funny how i never had a dipstick in my g35. it was just the plug with no stick. i had one of the very first 500 that came to the states. maybe they forgot...
Old Apr 18, 2007 | 09:31 PM
g035sedan's Avatar
or maybe it broke off and is just sitting there inside. that's what i've read on here.
Old Apr 25, 2007 | 11:11 AM
Pearl05G's Avatar
Heres a pics for anyone that cant find it, although very simple..
Old Sep 14, 2009 | 07:22 PM
iafzal's Avatar
can anyone confirm if the dipstick is present or you have to buy one?
I have 2003.5 G35.
thx
Old Sep 16, 2009 | 01:49 PM
bythabay's Avatar
I have 2003.5 G35.
thx
You can just unscrew the existing handle and see if there is a dipstick attached to the end. In all honesty, trying to read the transmission fluid level according to the directions is very difficult.
Old Sep 16, 2009 | 11:54 PM
rcdash's Avatar
It's not that bad in daylight. Early sedans did not have a dipstick. You can get a measuring stick from the dealer I think though.
Old Jun 20, 2011 | 05:23 PM
jimNC's Avatar
After reading the FSM, I agree - and you have to have special equipment. But if you just measure how much you drain and fill it with the exact same amount, you're fine correct?
I think I remember reading if you drain/fill you will use 5-6 qt. of Matic-J.
Old Jul 2, 2011 | 03:29 PM
MikeDG's Avatar
^ That is how I've done my drain/fills. Just replace the old fluid with the same amount that drained. Both times I've done it about 4 quarts drained from the pan. I suggest letting the tranny cool off throughly so that you are measuring cold vs. cold fluid.
Old Sep 20, 2011 | 06:48 PM
exiledtrinib0y's Avatar
matic -s is the new atf to use if you see matic-j its probably an old bottle
ZoominG35
Dec 6, 2015 03:11 PM
frankywashere
Aug 31, 2015 12:22 AM
sofa king
19 Inch
Aug 9, 2015 04:10 PM
Srinidhi
Aug 7, 2015 03:38 PM
newbdriver01
Jul 15, 2015 06:10 PM
