Battery just died and car wont start, no idea why lol
Old Jan 9, 2008 | 06:38 PM
partyman66's Avatar
Originally Posted by nycityinsomniac
so the battery is draining and its not even on the car? what the hell
Yep.. Piece of crap OEM Battery in our car for sure. My car is a 2004 and the original battery barely works after 3.5 years of ownership, yet I still have the original battery in my 2001 Tacoma, and that battery was made in July of 2000.... yet that thing starts like a champ every day, no matter how cold it is. There really is no excuse for a battery to be this bad that quick though... my battery has been weak in my G since around the 2 to 2.5 year mark.
Whatever though.. I look at it as a forced opportunity to upgrade one of the cars OEM weaknesses by going with a better and lighter battery.
Old Jan 9, 2008 | 06:50 PM
partyman66's Avatar
Originally Posted by AdamJ
You shouldn't be charging a battery like that
I didn't see that rule mentioned in the Battery Rules Constitution.... I sure hope the battery police don't try to arrest me for doing this
It's not dangerous to charge a battery the way I'm doing it, so I'm just going to coninue doing it since the battery is already on the way out, and hopefully it will have enough juice to get through another year or so.... but if not, I honestly don't care enough to get worked up about the small expense of a new battery. I am more annoyed by the fact that there seems to be a lot of individual things about G35's that are not of sufficient quality when taken as a whole... such as the paint, interior fit and finish(rattles), etc, and I adore my car... so that lack of quality rearing its head in new ways as time goes on sort of tarnishes the perception of the vehicle as its owner.
I can't really use a trickle charger right now anyways because I'm not allowed to run a power wire out to my car and leave it out there overnight where I'm living at the moment, and I don't want to have a trickle charger hooked up to the battery inside the house because it requires adequate ventilation to prevent an explostion hazard due to the Hydrogen emission of a charging automotive battery(even at low voltage).
Old Jan 9, 2008 | 07:42 PM
nycityinsomniac's Avatar
just bought an optima red top, im not taking any chances, thanks guys.
Old Jan 9, 2008 | 09:21 PM
CCG35's Avatar
When do you have to replace the stock battery? There's a lot of heat and humidity in FL so the water evaporates.
Old Jan 9, 2008 | 09:25 PM
in2win's Avatar
theres so many factors that go into how long a battery will last. Washing your car with the strero on for hours and then not driving it will slowly kill it. Heat is terrible for batterys. Your lucky if you get a battery to last 3 years in CA, Arizona cars are probably worse. My 03 Nissan battery to signifacntly smaller than any rplacement I could get. Its not mileage that determines how many miles, a battery and the odometer are not connected, every 3-4 years is normal.
Old Jan 9, 2008 | 11:08 PM
partyman66's Avatar
I usually get 6-8 years out of most of mine, but I guess I've been lucky..... then came the G35.
Basically you don't replace a battery just to replace it, unless you have new power needs driven by a high drain stereo system or other auxilliary electronic gadgetry/components which you plan on using a lot with the motor off(usually these also require a higher output alternator if you plan on running them consistently with the car on). Most of the time you'd replace a battery because it is either leaking or not performing adequately(battery consistently dying/car starting weaker than normal, etc). Really cold weather is where you can really notice a battery needing replacement.
Old Jan 10, 2008 | 03:29 AM
2EFNFAST's Avatar
Originally Posted by partyman66
Yep.. Piece of crap OEM Battery in our car for sure..
Maybe our batteries are fine and you just suck?
Jan/03 here with the original battery, and I drive it maybe once or twice a week. Sits most of the time.
Old Jan 10, 2008 | 03:20 PM
partyman66's Avatar
This thread probably wouldn't exist if that was the case.
Old Jan 11, 2008 | 01:47 AM
in2win's Avatar
I just replaced the original battery from november of 2002. I might be you draining the battery way down, heat, cold or a lemon battery or alternator.
chinee
Jun 10, 2024 07:48 PM
mike730
Jan 12, 2018 04:25 PM
Karnicle
Jul 23, 2015 05:08 AM
kenthung
Jul 21, 2015 05:56 AM
