Need Help with Winshield Wiper (Doesn't spray)
Old Feb 21, 2009 | 05:25 PM
RedArmyMMIX's Avatar
Hi guys,
I wanted to know if anyone had this happen and if they found a way to fix it.
I have 2003 G35 Sedan. My passenger side wiper doesn't spray. There is a little bit coming out, but not enough to spray the entire area.
I read somewhere about trying to poke the spray hole with a needle, which I did, but no difference. There are three holes, and all of them spew a little out, so I doubt its the holes.
Is there something else I can check?
Old Feb 21, 2009 | 05:58 PM
Seymore's Avatar
I had one jet get clogged once. I had the dealer fix it under warranty while I was in for a few other things. I'm not sure what they did, but it works great now. So, worse comes to worse, you could just have the dealer take care of it.
Old Feb 21, 2009 | 08:24 PM
Progress's Avatar
My driver side nozzle (in my Maxima) stopped working for a while. It turned out my FSTB was pinching the hose and preventing fluid from passing through to the nozzle. Could be that.
Old Feb 21, 2009 | 08:59 PM
rustyeleio's Avatar
Try the needle a few times. Helps if someone else is pressing the button to prevent the build up from falling inward then clogging the next time you spray. Also, like the previous poster said, trace the water hose for any kinks. Good luck!
Old Feb 21, 2009 | 09:45 PM
jutn35's Avatar
G35 Coupe
Calcium build up in the tubes ?
Old Feb 22, 2009 | 11:00 PM
Progress's Avatar
There's calcium in washer fluid?
Old Feb 23, 2009 | 01:21 AM
gr8huntr's Avatar
No calcium in wiper fluid...a needle isnt long enuff ...you have air compressor take the line off and try blowing it out...it might work...
Old Feb 23, 2009 | 11:34 PM
shakin's Avatar
I had this exact problem and it turned out that the plastic end where the wiper hose connects to near the hood was broken. Some fluid was squirting out the hole, but it wasn't making it into the hose because the hose was off.
It was a cheap fix.
Old Feb 25, 2009 | 01:33 PM
Thanks for the tip. I opened the hood and started inspecting the lower end of the wiperblade arm, I noticed the tube that carried the liquid was pinched by a piece of metal that was ment to keep the tube secured. So all it took was loosening the pressure from the clip.
Thanks for all your help guys.
Dallsinghjr1
Sep 17, 2023 11:25 AM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
BradMD_96
Oct 6, 2015 09:31 AM
markbilo
Sep 30, 2015 01:33 AM
