05 Coupe. Almost all of my dash lights on, VCP,Slip, Brake..
Old Jan 5, 2010 | 09:41 AM
AuburnG35's Avatar
Is anyone else having this problem??? It did it for the first time ever this morning. It was 13 degrees here this morning but I let it warm up first.. Seemed as though there was a huge reduced power output when throttle applied.. I went from 80 degree weather this weekend to 13 degree weather.. Is it the cold weather doing it???
Calvin's Avatar
Overglorified Altima
Check your brake fluid.
Old Jan 5, 2010 | 09:53 AM
Heinz's Avatar
When all the dash lights in other Nissan cars lights, the problem is the diodes in the alternator is deffect, so you have to check it.
Old Jan 5, 2010 | 10:18 AM
AuburnG35's Avatar
Did not seem as though it was an alternator issue, since I had a maxima before this that had continous problems with that.. I am just hoping that it is the cold weather messing with the readings.. I have not had a single problem with the car since I have owned it.. 8 months.. I will def check the brake fluid as well.. Appreciate it guys...
Mry
Mar 3, 2023 01:03 AM
wonderizm
Sep 24, 2015 03:09 AM
Wayne9011
Aug 17, 2015 01:24 AM
Wayne9011
Jul 27, 2015 11:25 AM
