VDC issue while cornering
Old Aug 17, 2010 | 04:40 PM
gotskidz?'s Avatar
Exclamation VDC issue while cornering
Recently I have been having a problem while going through corners going up or down hills. It seems that the VDC will kick in and it kind of stalls briefly and the "slip" light will come on. It happens anywhere from apx 25-45mph depending on the corner. A couple days ago I turned the VDC off and drove the same corners as i normally would and it seemed to stop doing whatever it was doing before. Any help would be great.
Thanks
Old Aug 18, 2010 | 11:40 AM
GrocryGettr's Avatar
I'm going to answer your question before you get completely flamed, so have a fire extinguisher ready.
When you corner hard your rear tires start to break traction and the traction control kicks in so you don't spin out. If you turn your VDC off, it disables this feature but it will be more dangerous if you do not have good driving skills.
Old Aug 18, 2010 | 11:41 AM
russ713's Avatar
^ either this or your tire sizes are too different and making the car "think" tires are spinning/sliding
Old Aug 18, 2010 | 12:52 PM
gotskidz?'s Avatar
haha, sorry, i'm aware of how the vdc works, i guess i should've been more descriptive in my first post. The thing is though I'm not cornering hard at all, it shouldn't be slipping. I've had the car for almost a year and its just been doing it recently. It doesn't feel like it regularly does when the vdc kicks in. It kind of feels like the front grabs, like the breaks are being tapped and pulls one side slightly. It usually slows me down enough to have to drop a gear.
Old Aug 18, 2010 | 12:58 PM
Deepdiver's Avatar
check and make sure you are not low on brake fluid.
Old Aug 21, 2010 | 05:22 PM
djamps's Avatar
Your front/rear tire wear is most likely the issue. I had this issue when my fronts were 50% and my rears were new. Didn't go away until I got new fronts.
Mry
Mar 3, 2023 01:03 AM
SiMpLyMoDiFiEd
The FX-Spot
Dec 2, 2021 04:35 PM
Wayne9011
Aug 17, 2015 01:24 AM
Wayne9011
Jul 27, 2015 11:25 AM
itschuckster
Jul 25, 2015 08:07 AM
