06 g35 wont rev past 2k rpm
Old Mar 4, 2011 | 10:18 PM
miickeyxd's Avatar
i have a 06 g35 and this just recently happen today. my car wont rev past 2k rpm and im throwing 3 codes;
1: P2103 throttle actuator control motor circut high
2: P0507 idle air controle systems revolutions
3: P2103 throttle actuator
can anyone explain these codes and what should i do? thanks.
Old Mar 6, 2011 | 08:30 PM
NJ 666's Avatar
If the battery is good you probably need a throttle plate/sensor assembly
Old Mar 7, 2011 | 01:55 PM
Wallyworld's Avatar
I have a 2007 g35x. Same thing happened to me today. Waiting for tow truck now. Unsure if codes are thrown. Can't wait to hear what garage has to say.
Old Mar 8, 2011 | 01:54 PM
GrocryGettr's Avatar
You guys need to replace the throttle body.
Old Mar 8, 2011 | 02:03 PM
SxExCx's Avatar
I would try to reset the TB before you replace it. Search and you will find the procedure.
Old Mar 8, 2011 | 04:26 PM
miickeyxd's Avatar
yea my battery is good, reset TB... this is what i found;
Throttle Valve Closed Position Learning
Operation Procedures
1. Make sure that accelerator pedal is fully released.
2. Turn ignition switch is ?ON?.
3. Turn ignition switch is ?OFF? wait at least 10 seconds.
Make sure that the throttle valve moves during above 10 seconds by confirming the operating sound.
06g35
Feb 14, 2022 05:59 AM
wuzz-upp
Oct 3, 2015 04:21 PM
vamarris
Sep 26, 2015 12:56 PM
sullivan72
Sep 22, 2015 11:39 PM
esotericrider
Northern California
Sep 10, 2015 02:28 AM
