Can really use a quick answer if available!!
Old Jan 28, 2014 | 07:52 PM
damicohead's Avatar
today i changed my transmission fluid and figured i would do the clutch at the same time....tranny is easy as pie...however, after i did my clutch fluid, the clutch is still acting lifeless....i did the correct bleed with a motive power bleeder and it was flowing in a steady stream...topped of the res and thought i would be good to go...is there something im missing here??? the clutch before this was fine, but a tiny bit sludgy.
Old Jan 28, 2014 | 09:00 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
I had a lot of trouble getting mine bled too, ended up using a MityVac vacuum bleeder attached to my compressor, and it worked perfectly. Had it done in about 10 minutes from park to bled.
Old Jan 28, 2014 | 09:12 PM
damicohead's Avatar
unfortunately i dont think the bleeding was the issue...i had it coming out in a steady stream with no bubbles...it just makes no sense to me why the clutch is still lifeless...i cant even change into gear
Old Jan 29, 2014 | 01:04 PM
damicohead's Avatar
corrected the problem....just did it the old fashion way with two people
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
suby01
Not G35 Related
May 25, 2016 03:07 PM
Learned Hand
Oct 1, 2015 09:02 AM
Jcruzg35
Sep 26, 2015 04:47 PM
