Rattle at Startup
Old Aug 19, 2014 | 04:30 PM
Circle_40's Avatar
Rattle at Startup
I Have a 2006 Sedan, and for as long as i've had the car (since it was new) there is a rattling sound whenever i start up the engine and begin to drive. It ALWAYS happens when i start it up when the engine when it is fully cooled, after i back out, put it in drive, then start to move, then comes the rattle. It sounds like its coming form under the car or engine somewhere. It lasts less than a second. Do any of you have this problem or know what it is?
Old Aug 19, 2014 | 04:52 PM
ihiryu's Avatar
Join the club, sounds like knocking on start up. Pretty common for us, mileage?
Old Aug 19, 2014 | 05:08 PM
Circle_40's Avatar
Around 150k but it's always happened. Glad to see i'm not alone. have you ever asked a mechanic about it?
Old Aug 19, 2014 | 05:09 PM
Circle_40's Avatar
You hear it after you start driving right? it sounds like a metal pan rattling for about a second.
Old Aug 19, 2014 | 05:12 PM
faiz23's Avatar
VTC Sprokets
https://g35driver.com/forums/g35-cou...up-engine.html
Originally Posted by Sam@GTM
There is a TSB to address a momentary noise after a cold start from the timing cover area,it get mistaken for a timing chain tensioner or guide ,there is a spring that keep tension on the VVT sprocket ,the spring brakes or get weekend witch will cause the noise ,these sprockets are not cheep there are about $500 give or take each. we have seen this problem mainly on the early 03-04 models .
Here is the TSB information from Nissan this was originally discovered on the maxmia/altima VQ35 engines but is also a known cause on the 350Z/G35.
Hope this helps
Sam
GT Motorsports
Old Aug 19, 2014 | 05:18 PM
Circle_40's Avatar
Thanks Faiz, but thats not the sound. it only happens after i put it in drive and start to move. it sounds like a metal pan expanding or something. Rattling is just the only word i can think of to describe it
Old Aug 19, 2014 | 05:25 PM
faiz23's Avatar
Could be the heat shield that is loose and rattling. You might also be hearing the chatter from the manual transmission. With the OEM flywheel you will get a small amount of rattle. With aftermarket lightened flywheel it will be much more pronounced compared to stock.
https://g35driver.com/forums/g35-sed...d-problem.html
https://g35driver.com/forums/g35-sed...eatshield.html
https://g35driver.com/forums/g35-sed...at-shield.html
https://g35driver.com/forums/g35-cou...elerating.html
Old Aug 20, 2014 | 11:56 AM
ihiryu's Avatar
Mine sounds like the videos that Faiz23 posted.
Old Aug 20, 2014 | 08:41 PM
Circle_40's Avatar
Sadly , this isnt the sound i'm talking about, i'll try to get a sound byte to upload
Old Aug 21, 2014 | 04:14 AM
Gwilly_713's Avatar
yeah I think I know what your talking about.
It happens even if your engine is warmed up already. Put it in Reverse (and back up), no sound. Put it in Drive, rattling sound appears. To me it sounds like a can with something lose inside it. Then it goes away after the first like 2-3 secs of driving.
Edit: oh I own an 06 a/t Sedan
Last edited by Gwilly_713; Aug 21, 2014 at 04:17 AM. Reason: * oh btw I have an 06 AT Sedan.
TNRocker
Sep 21, 2015 08:36 AM
socaldavid
Sep 5, 2015 04:35 AM
leli_11
Aug 10, 2015 08:25 PM
kinetek
Aug 3, 2015 04:25 PM
THMotorsports
Midwestern
Jul 22, 2015 10:27 AM
