(Slip light VDC light Off) keeps coming on
Old Jul 22, 2018 | 06:02 PM
Mry's Avatar
Mry
Tech package
Originally Posted by Scottwax
Worn front suspension can also cause these lights (SLIP/VDC) especially if your steering wheel isn't centered while going straight.
Good to know...these lights can be like a...
'Check Engine Light' which is equivalent of
Old Dec 31, 2018 | 11:01 AM
maxime's Avatar
Auto5
Hello,
Not so long ago, I reached 77777
Lucky number?
max
Old Jan 24, 2021 | 11:42 PM
Joneche's Avatar
Originally Posted by djjojo860
Mry, did you ever find the solution? I’m also from CT with this exact problem
djjojo860, did you ever find the solution? I’m also from CT with this exact problem (maybe the problem is CT, hahaha). I following the thread of Mry, but did you fix yours?
Old Jan 25, 2021 | 09:00 AM
Mry's Avatar
Mry
Tech package
djjojo860..yes I did find the solution....Its your CRANKSHAFT sensor INFINITI is notorious for these falling ever 1.5 years needed a replacement. By the way you must know because you own it that Infiniti even if you didn't buy it from the dealer they honor your car for life and they will give you a free rental car if you let them work on your car I usually will take it to Harte.
also if you're running low on brake fluid your slip light will come on check that too usually sensor
Actually in on my 2nd 2006 g35× picking it up tomorrow signing the loan papers today (MINT) with tech pkg.
Love my G35X It has been my savor in the snow
By the way I drove on Michelin all season that car never got me stuck here in Connecticut
Any other question please ask
Old Mar 3, 2023 | 12:08 AM
Jayro7777's Avatar
2008 G35X Sedan
Mry, did you ever have any issues with your call stalling out while turning in reverse? Like backing out of an alley way or parking spot. My 08 G35X has been doing that along with stalling out while making a turn from being stopped at a red light or stop sign. Replaced and changed all 4 CSP sensors about 9 months ago and seemed to fix the problem but has recently been doing it again.
Old Mar 3, 2023 | 01:03 AM
Mry's Avatar
Mry
Tech package
Depends on VIN#
My white one 06 standard package all the time believe it was the right Bank sensor like every 9 months in that car only lasted you 178,000 miles I wasn't a happy camper. . It would love to die going down the highway basically just started off as hard starting That's The telltale sign and then it started rumbling like it was going to stall at a light or what would but if you're going on the highway it doesn't care ... good luck with no power steeringb
Now this one I got into 2006 with the tech package doesn't have that problem but it does like to drink an extra quart of oil periodically
Actually my last article was that it was every year and a half but Infinite reminding me that it was much more than that
PlacidoVq
Jun 30, 2018 12:48 PM
jnova
Feb 4, 2012 01:03 PM
BJD275
Sep 21, 2009 07:11 PM
Cali G
V36 Brakes, Suspension, Wheels & Tires
Sep 22, 2008 11:20 AM
