Finding an open circuit? (Cig Lighter & Yaw Sensor)
Old Jun 3, 2016 | 08:06 AM
smokdad's Avatar
Long story short my switch I was installing to completely disable traction control was faulty and fried the 12v wire (orange) to the yaw sensor and the fuse(s) is/are fine. i then wired the switch to the red wire of the console cig lighter. Also fried the wire making me realize its the switch. output is between 0 and .02 V on both wires.
How do i locate where the open part of the circuit is or what is a good wire to splice and connect these both to to fix them? I need something simple that turns on whenever the car is on so seat heater or hazard lights are a bad idea i assume. any ideas? the simpler the better
additionally, I'm positive it was a bad switch w/ gnd, not a faulty wiring job by me. I have the service manual as well. thanks!
03 G35 Coupe A/T
Old Jun 3, 2016 | 09:57 AM
yosip1115's Avatar
You don't need 12v to disable traction control. You just tap a switch into the orange wire in the center console. It is the wire that supplies 12v to the YAW sensor.
If you need 12v switched for a different project, use one of these.
FAST Shipping! Mini Blade Fuse Tap Holder Add A Circuit Line Mini Low Profile ATM + 5A 7.5A 10A 15A, Car Add a Fuse Automotive Car: Industrial Products: Amazon.com: Industrial & Scientific FAST Shipping! Mini Blade Fuse Tap Holder Add A Circuit Line Mini Low Profile ATM + 5A 7.5A 10A 15A, Car Add a Fuse Automotive Car: Industrial Products: Amazon.com: Industrial & Scientific
Old Jun 3, 2016 | 12:49 PM
smokdad's Avatar
Hey sorry if i wasn't clear. that's what i was doing but that 12v wire no longer works (short circuit ruined it?) thus traction control is always off. i'm just trying to fix that and install a switch to manually control it. Thanks!
Old Oct 15, 2020 | 10:56 AM
G3505DEUser's Avatar
g35
Just wondering did u ever find a solution or the fuse that blew the wire? I've tried getting power back to the orange one but no fuse I look at seems fried and I dont wanna splice into another wire for power to traction
CrustyMilkBagz
Nov 2, 2020 08:35 AM
hotrod123
V36 General Tech Questions
11
Oct 21, 2017 05:52 AM
WhiteonWheat
Sep 10, 2009 01:31 PM
dddragon2
Aug 26, 2009 04:13 PM
KPierson
May 28, 2009 02:36 PM
