VDC off and Slip light on
Old Dec 15, 2017 | 08:50 PM
tacticsG35's Avatar
Hi, I had a "SES" light com on for a camshaft position sensor bank 2 for the driver side on a 2004 infiniti g35 automatic transmission. I have then replaced the sensor and plugged the battery back on and the "SES" light went away but the "VDC off" and "Slip" light are still on. All three lights appeared after I got the SES light for the sensor. any help what could be wrong still?
Old Dec 15, 2017 | 08:53 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Are you sure you got the correct sensor? The driver/passenger side are different sensors.
EDIT: Did you get an OEM sensor or some random aftermarket one? Aftermarket sensors are NOTORIOUS for not working properly or failing quickly.
Old Dec 15, 2017 | 08:56 PM
tacticsG35's Avatar
Yeah I read the code with my OBD2 Scanner. and it was OEM.
Old Dec 15, 2017 | 08:59 PM
cleric670's Avatar
BANNED!!!
And it's still the SAME code yes? And when you clear the code it comes right back?
Old Dec 15, 2017 | 09:04 PM
tacticsG35's Avatar
No. The Code Cleared. The "SES" light also Cleared. But the "VDC off" and the "Slip" lights are still on and haven't cleared yet.
Old Dec 15, 2017 | 09:05 PM
cleric670's Avatar
BANNED!!!
Well those aren't engine related codes so I'd start by checking to make sure your brake fluid isn't low and the pads aren't worn down.
Old Dec 15, 2017 | 09:09 PM
tacticsG35's Avatar
Talking VDC off and Slip light on
Ok, thanks. that relives some worries I had. will check pads after work tomorrow because I just topped off all the fluids but will re-check the break fluid levels again.
Old Dec 15, 2017 | 09:15 PM
Urbanengineer's Avatar
It means the yaw sensor can't do its job. Likely just brake fluid.
Old Mar 17, 2018 | 01:09 PM
murderface's Avatar
Brakes
VDC off and Slip light on would have to be something with the sensors that connect to the rear differential or the bosche traction control unit under your center console are my thoughts. I would start at the back of the car and take a look at the two sensors that connect to the rear diff and plug harness. Chase it back and look for any damage to the wiring harness. Also check fuses. This could be related to brakes too so best of luck.
Just out of curiosity are you able to drift/slide the car without the brakes auto engaging? I found on my 06 that even with VDC off I still get the annoying safety features engaging when trying to get shwifty or slide the car. If I slip the car enough and I get those lights to stay on its no longer a problem. Turning the car off and back on makes them go away. There is a video out there of a guy connecting a switch to the wiring harness of bosche unit under center console to get a true traction control shutoff switch in place.
Old May 3, 2020 | 08:47 PM
adammickel's Avatar
Moderator EDIT: Banned for botting.
Kennycaine
Jan 1, 2020 11:04 AM
bigjee
Apr 24, 2018 12:42 PM
The_Silencer
Apr 23, 2018 11:24 AM
Mrs.Valdez23
May 7, 2015 09:40 AM
