VDC and slip light on!
Old Feb 21, 2019 | 01:02 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
The number 1 reason for those lights coming on is just low brake fluid, that should always be the first thing to check. Beyond that you need to put it on a scanner to find out what EXACTLY the ECM found to be wrong otherwise it's just a lot of guesswork, could be a wheel speed sensor was damaged during the exhaust install.
Battery light coming on is unrelated, sounds like you need to troubleshoot the charging system, might just be the battery terminal is dirty or loose.
Mark7
Dec 21, 2019 06:22 PM
bendigi
Mar 20, 2015 12:44 AM
jowca123
Jul 19, 2014 12:09 PM
netcbc
Canada
19
Dec 3, 2007 06:10 PM
VQPWNAGE03
Aug 31, 2007 02:19 AM
