2004 g35 passenger window not working
Old Jan 11, 2019 | 04:53 AM
marcoxv's Avatar
Hey guys, I was wondering if any of you guys could help me out. My passenger window finally gave out and got stuck at the bottom after my friend used the auto down function. Before this happened, it would intermittently work. Banging the side of the door would fix it every now and then. Today, I replaced the motor and the same symptoms occur. The motor clicks and moves just a tiny bit. I've tried cleaning the contacts of the switches after replacing my motor, used both driver and passenger switches, and resetting the motor. I'll try manually try driving the window up with a socket wrench to see if the window will go up at all. In the mean time, if anyone could offer some help I'd greatly appreciate it.
Thank you
Old Jan 11, 2019 | 01:49 PM
04Joe's Avatar
window motor? is supposed to be a common issue on the G35 coupe because of the window size. even if you have a sedan, it's likely the problem.
Old Jan 11, 2019 | 02:55 PM
marcoxv's Avatar
I wish that was the problem. I replaced it already and I'm still getting the same symptoms
Old Jan 11, 2019 | 04:09 PM
Scorpi0's Avatar
U gotta reprogram the motor. Theres a button on it.
https://www.infinitihelp.com/diy/gco..._procedure.php
Old Feb 13, 2023 | 07:23 AM
Infinitisrule's Avatar
Loaded midnight blue w/everything.
reprogramming
The motor is still working on the passenger side drivers window, so all I needed to replace was the power window switch, the right passenger rear motor is shot and I don't think I'm going to replace it later, I don't use it and it is @$300 w/p/l...below is what I got to fix the 3 windows w/working motors, let the mechanic reprogram it for you if you don't want to, mine did it for nothing.
Amazon Amazon
YOU HAVE GOT TO GET ONE W/ALL 4 SWITCHES, they sell them seperately for each window but this 4-1 unit is what I got/was told to get and it works great, $50 w/tax on Amazon...they sell motors too but they start around $170 before labor, you replaced your motor so 99.9% sure the power window switch link I sent you is what you need, they have them as cheap as $25 but pay for the $50 model, works great. If your motor is fried in the door this won't help you, takes @ 15-20 min to install, 50 for the part 68 for the labor, hope this wasn't too confusing, good luck, my 3 windows w/working motor are working fine now, but again, you have to buy a model like I posted, not individual ones for each door. Good luck!
Last edited by Infinitisrule; Feb 13, 2023 at 07:33 AM. Reason: adding to the answer
lil_will
Apr 16, 2013 02:23 AM
JPMM
Jun 7, 2011 04:42 AM
sdwhatley
Jan 1, 2010 08:43 PM
MidnightBlue
Canada
Apr 19, 2008 08:37 AM
orangenblue
Mar 28, 2007 09:50 AM
