Dead battery
Old Nov 11, 2019 | 11:36 PM
DeadmeatXJ's Avatar
Journey
Dead battery
I have an 07 Journey that recently started draining the battery overnight. Took the battery back to Autozone they tested and charged it. Voltage across battery terminals while running reads 14.3 volts. Performed a parasitic draw test, fluctuated between 9A - 0.18A for 5 minutes then held at 0.18A. Pulled every fuse out of all three fuse locations and never saw a drop below the 0.18A. I’m stuck. Gonna leave battery disconnected overnight and check voltage. Any thoughts would be greatly appreciated.
Old Nov 12, 2019 | 11:05 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Usually it's the stereo draining current, specifically the cd changer.
Old Nov 12, 2019 | 01:05 PM
DeadmeatXJ's Avatar
Journey
Thanks. I’ve seen that to be the case. This car does not have a changer in the trunk. I have disconnected the audio fuse and checked for voltage drop. I just can’t figure out where this power is going.
kane08
Feb 19, 2018 11:29 AM
g35fnatic
Mar 7, 2016 05:23 PM
junCakes
Feb 28, 2012 02:12 AM
pachieng
Sep 28, 2011 01:50 AM
DeadCellShadix
Mar 11, 2008 09:10 PM
